onionfmr
Need to change the fuel filters on my 1754. Apparently, according to the dealer, there are two filters. Same filters fit a 1736 to 1759? Anybody changed their filters? Comments or advice? Thanks.
My 1736 has 2 filters both canister though slightly different. The spin on with mine is the hydraulic filter.
onionfmr, A double fuel filter(same part) is standard on the MF tractors I have driven or owned.
Quick tip, when changing fuel, filters fill the filter with fuel first, then fit. There is a knack in this. When you get the knack you will be able to change the filters and fire up and go without airlock problems.
My 1754 just ran out of fuel. My fault....totally. Of course it won't start now after adding fuel. On the right side of the tractor, I found the oil filter beside the dip stick and on the other side of the tractor there's a filter that looks like a oil filter but I believe it is one of the mentioned fuel filter. Bottom line, I'm searching for the steps to get the air out of the lines and a slap across the head for running it out of fuel. It's a 2015 1754. Gulp.
