3 point lift not working
   / 3 point lift not working
thanks, I will have to get someone that knows more than I do about hydraulics to take it apart.
Forgot to mention the tractor is a 2010. I did check the hydraulic filter and cleaned it. The fluid that came out of it was super clear, not dirty at all.
Another update, after about 5 hours I got the cover off. the cover was obviously put on before the cab..lol. I had to drill some holes in the cab to get some of the bolts up through.
So, here is what I figured out. Like i mentioned earlier I dont know much about hydraulics. With the cover off I moved the 3 point arms up and down and could see the rod moving in the piston. I put my hand in the cylinder and the rod was lying against the cylinder wall. At the end of the rod I could feel the end and it felt like there was a threaded hole there. Im not 100% sure on that but shouldnt it be connected to something? I will have to drain the rest of the fluid to see better I guess. I am hesitant to disassemble too much more at this point.
Any suggestions/ comments would be greatly appreciated. I will attach a pic.
   / 3 point lift not working #14
On 3 pt hitches the rods are never usually connected to the piston, there is usually just a ball on the end of the rod that sits in a socket on the piston, it allows the arms to float.
thanks I will keep looking, going to drain the rest of the fluid today.
   / 3 point lift not working #16
("I am hesitant to disassemble too much more at this point.") <<<<<<I know that feeling, guess you have to come to a decision, am I going to make it worse if I keep going, or am I gonna to find the problem if I do keep going and most important will I remember how it goes back together, check mate would be you have it apart but still know what the problem is, but the tractor still works, just no 3 point lift.
If it does go south, at last resort you can mount a 12v 10,000lb winch with remote on the ropes to lift the 3 point lift, that's what I did 8 years ago to lift my pto winch, mine is a little on the weak side when I have 5-ish- 6-8" trees on it.
   / 3 point lift not working #17
I would be willing to bet it is a control valve problem there is not much inside the 3pt hitch that can go wrong most times it is the valves or the tractor hydraulic system. Do you have a loader or any other point you can check hyd flow and pressure?
I am floating it to a tractor mechanic. I will update the status...hopefully he can fix it and it isnt too costly.
yes i have a loader so the pump is fine. Ken, from Asian tractor parts figures its probably a valve. He is really good to deal with! Gonna take it to get it checked out.
I took a few pics just before I took it to a tractor mechanic. Once I drained all the oil out of it I could see that the lift lever when in the down position touches a plunger that goes in, in the full down position. When I put the lever in full lift position the plunger goes out half way. Basically from 3/4 to full lift position the lever isn't touching anything which I wondering if the plunger is stuck?? I am attaching a few pics.
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
Bad Boy Outlaw XP...
2015 Freightliner Ambulance (A50323)
2015 Freightliner...
2014 PETERBILT 388 AUTO TRANSPORTER (A51222)
2014 PETERBILT 388...
