Rotary Cutter What size rotary cutter for 40hp tractor
   / What size rotary cutter for 40hp tractor #1
WVH1977
Richmond, VA
Massey 2860M Cab, Massey 1E.35, Gravely Pro-Turn 560, 1989 Ford D47 Dump Truck John Deere LX178
I am looking at purchasing a Woods BB600X rotary cutter for my New Holland TC40 (35 pto hp). Is this too much cutter for my tractor? I will be cutting pine saplings that are 3 years old mixed with briars and broom straw. I would say the majority of the pine saplings are 2" or less in diameter and some that are a little larger. I have been told by two dealers that my tractor will handle this size cutter. I am wondering if I would be better off with the mid-duty BB60X or BB72X. Most of the cutting will be done on flat land, about 3 acres. There is a slope of about 5 to 10 degrees that rolls for about 400 feet that I will be cutting on in the future, mostly trails. I just want to make sure I purchase the right piece of equipment for the size tractor that I have. The tractor has a FEL and a 3 pt. lifting capacity of 2400 lbs.
Thanks for any advice/input that will be provided.
   / What size rotary cutter for 40hp tractor #2
Your tractor should handle a 60" cutter with no problem, I use a 60" cutter on my 34 hp tractor without any problems.
   / What size rotary cutter for 40hp tractor #3
I have a Ford 3000 that puts out somewhere around 38 engine hp. I run a Branson 6' med duty with no problems on it. I have a 24 hp Branson 2400 that will run a 5ft in 3rd of 6 F gears, PTO rpm.
   / What size rotary cutter for 40hp tractor #4
A 5' mower is probably about right. A 6' mower would probably work on your tractor too, but is borderline too big, particularly if you are doing the heavy duty cutting like you mentioned .
   / What size rotary cutter for 40hp tractor #5
What Cougsfan said. As a rule of thumb you size those rotary implements by the width between your tyres (tiller/slasher/mower).
Your terrain may allow you to go a wee bit bigger. A call to your dealership will confirm.
   / What size rotary cutter for 40hp tractor #6
I also agree with Cougsfan. I personally would not go with a 6'.
Thanks for the comments so far. I am really leaning towards the 5' cutter. However, my tractor width is 6' and I would be sacrificing covering my tracks. I used to have a 5' tiller and my tractor handled that extremely well. I upgraded to a 6' tiller to cover my tracks and the tractor handles it well but not as good as the 5' tiller I had. The BB600X weighs 1068 lbs. The BB72X weighs 800 lbs.
   / What size rotary cutter for 40hp tractor #8
I would want to cover the width of my tires. Your tractor will run the 6' cutter.
   / What size rotary cutter for 40hp tractor #9
I would want something that would cover my tracks. I think the 6' will be fine, you can always creep through the heavy stuff in low gear.
Go a little faster with the 5' or a little slower with the 6' and cut the full width of the tractor.
I appreciate all the responses I have received so far. Thank you for the feedback. I went back over to the property yesterday that I just bought and really looked it over good. Most of the pines are 2 to 1/2" diameter and quite a few 3" pines. Carried my wooden rule with me. LOL. I am really leaning towards the Heavy Duty BB600X. It weighs 1,068 lbs. and will cut up to 3". The property I bought is 16 acres and I will be doing lots of heavy clearing and cutting trails over the next several years, after the initial 3 acre clearing. I think once I get it cleared the way I want it I will sell the BB600X and get the mid-duty BB72X to do maintenance cutting. I really think the heavy-duty BB720X would be a bit much for my tractor. I know my grapple bucket will get a good work out as well. Decisions, Decisions.
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
Hose Reel (A55787)
Hose Reel (A55787)
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2002 Bobcat 763 High Flow Compact Wheel Loader Skid Steer (A55851)
2002 Bobcat 763...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
2025 Spirit Electric Scooter (A55853)
2025 Spirit...
