Max26 vs Mac 24
/ Max26 vs Mac 24 #1
Lepricon
Ashburn,Ontario
None yet
Hi Gang.
Bit if a dilemma. I am looking to purchase a subcompact for my 2ac lot. I plan to use a tractor for mowing.. Major landscaping.. Snowplowing.. Gardening.. Etc
I have it narrowed down to a Max24 which I like due to the solid steel construction and feel vs bx25/1720 etc.
The dilemma : Dealer has Max26 with 30 hours and is willing to let it go for $2500 CDN more then the brand new Max 24. Is it way more of a tractor? Would ya'll pay more for the extra hp and a little weight.
What do you think
/ Max26 vs Mac 24 #2
Depends on the mowing. If it's your "finished" yard the extra weight won't help. But if it's just open areas you knock down in the spring or say no problem. Everything else; I'd go with the bigger one.
/ Max26 vs Mac 24 #3
Welcome to TBN!
As long as the warranty is still good on the 26, it may be worth it. If your "major landscaping" consists of moving much earth, any extra built-in weight is an advantage. I don't think either weigh enough to make much difference on mowing. I mow with 3x the tractor of a Max. I'd expect a shiny new set of mower blades to be installed at no additional cost.
/ Max26 vs Mac 24 #4
Hi Gang.
What do you think
I did not know that there was $2500 CDN difference between a Max26 and Max24, did you check actual List?
30 hours is worth some negotiation. Max 26 will be better in snow with chains on all tires, as it's tires are larger. Max26 is a light tractor, especially without loaded tires and loader removed.
My Max28 is weighted to 3400 Lbs heavy, and is not bad on a lawn, especially compared to my L39.
/ Max26 vs Mac 24 #5
The max is no comparison to the XL... in real life when they are put to work the XL is twice the tractor... id pay it in a heartbeat
/ Max26 vs Mac 24 #6
I have a mmm on my max, mows great, no damage to my yard. Have R4's on it. And for it's size it really is a workhorse.
Wooden Table (A64557)
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2013 Infiniti JX35 AWD SUV (A64557)
2013 Infiniti JX35...
2019 Toyota Mirai Sedan (A64557)
2019 Toyota Mirai...
KMC 18' FIELD CULTIVATOR (A64278)
KMC 18' FIELD...
2022 EZ-GO ELITE...
