Float Position?
/ Float Position? #21
Are you guys on solid Asphalt or Concrete? Level Ground? If you play this on Gravel with just a a slight decline, she digs in with her dead weight and and tries to do a wheelie.
My driveway is crushed rock. My technique works well for me. It does take a bit of time to get the amount of curl just right. Not enough and it digs in. Too much and it rides up on the snow. I used the same technique on my B2620,which is quite similar to your tractor,and it worked fine.
/ Float Position?
Yes, It is what it is. You have to get the curl 'just right' or it's like being a yahoo driving drunk :)
Genie S40 Boom Lift (A64047)
Genie S40 Boom...
WACKER NEUSON LIGHT TOWER (A63569)
WACKER NEUSON...
2007 PETERBILT 340 ROLL OFF TRUCK (A59909)
2007 PETERBILT 340...
SET OF (20) ACE CATTLE PANELS W/CONNECTION JOINTS (A63569)
SET OF (20) ACE...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
Freightliner Cascadia (A63118)
Freightliner...
