Replacing trailer brake battery with capacitors
   / Replacing trailer brake battery with capacitors #21
How long do the brakes stay on? My guess is they wouldn't do 15 seconds running off capacitors.
   / Replacing trailer brake battery with capacitors #22
Most state laws require brakes to hold for 15 minutes. Four wheel brakes draw 12 amps. I don't think many LI packs will do that without overheating.
Thank you for the lively debate! I enjoy the banters greatly. I think I'll pull the battery out and put in on a maintainer. Long term I'll make a quick plug connect so it'll be just a slap it on and go.
   / Replacing trailer brake battery with capacitors #24
If you want to make it unforgettable, use a vehicle side plug to match the light plug. You will never forget to plug the battery back in that way.
Aaron Z
   / Replacing trailer brake battery with capacitors #25
Aaron Z
Ya, like that plan. Portable as needed, easy to hook up & imposible to forget.
   / Replacing trailer brake battery with capacitors #26
This is how we have done it for 20 years. Cheap and easy!
2022 CATERPILLAR D4 LGP CRAWLER DOZER (A51242)
2022 CATERPILLAR...
2011 Kubota M7040SUD 68HP 4WD Utility Loader Tractor (A49461)
2011 Kubota...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
3in Poly Pipe (A49461)
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A51039)
Texas Post Driver...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
