Agreed. The engine throttle control can be used as a whole system flow control as well.The one thing that is odd to me is the needle valve after the pump. I wouldn't put it there without a relief valve before the needle valve.
If you are concerned about controlling function speed, it should be done on the individual functions. Yes that is more pieces, but that is the right way to get your function speeds where you want them with basic control valves.
Using the CV with PB will also result in single function operation. Whenever the first spool in the line of spools is activated, it will rob any available oil to any other spool further down the line. In other words, you wont be able to, as an ex, lift the boom and swing it at the same time. You will either lift then swing or swing then lift, just depending on which function is first in the line of spools. Feathering the levers will allow some functional ability of multiple spools at the same time
I see no reason to separate the two controls valves by using a flow divider as suggested. The second control valve seems to be dedicated to the 4 outrigger cyl's. Since the outriggers would only be extended/retracted while setting up the machine to dig and then not being used at the same time while digging. If this was a closed system, (I assume you are building a open system), and you where using a variable displacement pump, you could tie/tee, the control valves into the pressure line and have pressure to both valves and be able to do more than one function at the same time.
I'll agree that a closed system would be ideal, but when I looked into it the cost went up quite a bit, that's why I suggested the split open center system. I just wish I had figured it out before I built mine.I agree with most everything others have said above.
Since you are building this from scratch you might consider using a closed system instead. This would give you better control of more than one function at a time. Being able to swing and control the boom at the same time comes to mind. You can use an open system but it is not as nice as a closed system can be. Just something to consider before you build this.
No the flow divider wouldn't benefit him as the valves are setup in the diagram.
I was suggesting dividing up the BH controls between the two valves so simultaneous operation of 2 functions could be achieved, this would place 2 stabilizers on one valve and 2 on the other. Since you're already using 2 control valves it would be a minor investment for a good increase in functionality.
If I was to build another BH I would do this, also it is nice somtimes to have float position on the main boom if possible, but definitely not a requirement.
OP, what size are you planning to build this? Cylinder size and desired speed will determine pump size.
It took me a minute and a reread of your other post to realize what you where suggesting. I agree, as long as the OP can live with the reduced flow. His 2.5in bore cyl are not going to provide a lot of force and I dont know how important speed is going to be. I would probably swap the speed reduction for improved functionality and a the flow divider would provide this.
To the OP.
1. Relief valve one way or both ways, does it matter, what kind?
I suggest before investing in a separate relief valve, you take a look at your control valve. Chances are your control valve already has a relief built in and no other purchase is necessary. You should always have a relief between the pump and the control valve. Your control valves should have the relief built in. Your question about one way or both ways doesnt really apply here and a second relief isnt necessary
2. Could I get away with an 8 horse gas engine?
Hp is in direct relation to pump flow and pressure. At what pressure so you intend to run this system. With standard gear pump, chances are you will not be able to run the 8gpm, or even the 6gpm at any decent pressure with just a 8hp engine.
3. Would I be better off with a 6 gpm pump at 2k RPM?
Many ways to mess with pump flows, rpms being one of them. If you idle down the engine to achieve desired flows, you will also reduce hp generated by the engine. Best to match required flows and pressure requirements with adequate eng. hp
4. Should the tank be a little higher than the pump for good flow or does it matter?
Maintaining fluid levels higher than the pump intake is always better. Oil levels lower than intake levels can cause the suction line to drain of oil when not pumping. Dry suction lines can damage the pump at startup. This doesnt mean the whole tank should be higher than the pump, just that the oil levels in the tank should be above the pump.
I want to operate at probably around 2000 to 2500 psi with enough umph to operate a small towable backhoe to dig and pick up relatively heavy stuff.... I have not purchased cylinders yet and could go up to 3 inch if necessary.
