New TC35 Owner
/ New TC35 Owner #1
mpilihp
Jefferson, ME
Pasquali 988
Just bought a 2005 TC35 and have a few questions,
It did not come with an owners manual, I searched the intnernet and there does not appear to be one available to download, can you only buy a hard copy?
There are several switches inside the cab I do not know what they do, two on the right side fender.
Also what switch is the glow p!ugs?
Thank you
Phil
/ New TC35 Owner #2
Be careful - I just checked a "free download" site and my security software warned me to not download from the site.
Anyhow - check with your local dealer - an owners manual should be free or at least not cost a fortune. If you are talking about a Service Manual - well, that's an entirely different can of fish.
I don't want to start a rant, but I wonder what everybody does with their OM's. Your lack of receiving one with the purchase of the tractor is FAR from rare.
Hang in there Phil - somebody who is familiar with your unit should be along soon to answer your questions.
/ New TC35 Owner #3
Thank you
Phil
I know you will love it.
Post some pictures. I am sure we can figure it out.
/ New TC35 Owner
Ok thanks i will when im back home, headed to camp!
/ New TC35 Owner #5
You can buy a manual on ebay for $25-$30. On my NH, there is no switch for glow plugs. You just turn the key to on (not crank) and the glow plug light comes on. When it goes off, you crank the engine.
/ New TC35 Owner
Hi thanks so where is thr glow plug indicator light?
/ New TC35 Owner #7
It's an amber light on the bottom of the dash - under the tach. It will come on, and then go off after 15 seconds or so.
/ New TC35 Owner
Hi all thanks for the info/help. I plan on changing all fluids and filters and planning on going with dealer UHF for the hydro system, I think the better fluid is F200?? WHile I'm at the dealer Ill ask about a manual.
As for indicators and controls in the cab, here is the first pic: I am guessing the glow plug indicator is the left most amber indicator? But what is the other one and what are the green indicators?
I didn't try it but I assume the big red switch in the middle is hazards?
IN this pic, what does this lever switch do? I tried it and see nothing happening, is it a blinker?
Pic 3 is on the right side over the right rear wheel, what does the red and green switches do?
Pic 4 what does the 'LOCK' lever lock?
Pic 5 below the steering wheel what does this lever do?
My last question is how fast should a TC35 be able to move in low range and then in high? Barely seams to move in low. When I was in high with throttle half way it struggled to go up a slight grade in my side driveway, I'm hoping that is not a sign of an issue.
Last when driving straight a long ways it seams the steering wanders to one way. Appears its fully hydraulic steering, could I have a leaking ram??
Thanks
~ Phil
/ New TC35 Owner #9
Cheap on EBay
Glow plugs, oil, battery. On the Right Parking brake and PTO. Not sure about green lights without looking at my tractor (turn signals?)
I didn't try it but I assume the big red switch in the middle is hazards? I think so
IN this pic, what does this lever switch do? I tried it and see nothing happening, is it a blinker? Signal lights
I don't have a cab, so no help,
Isn't that your tilt steering wheel lock?
Try it higher RPMs
Thanks
~ Phil
Answers in quote
/ New TC35 Owner #10
I just confirmed on my tractor. The switch on the dash with the green panel turns on the headlights. The one with the red panel is the emergency flashers. The rotary knob turns on different configurations of the lights. two of the green panels in your dash will be turn signals.
/ New TC35 Owner
Thanks for the help all, so the only real mystery is the two switches the third pic on the right side of the seat (Right rear fender) any thoughts?
Im also wondering if it has a steering issue, didn't notice it when I drove it around in the sellers lot but if I leave the wheel alone and go straight it sometimes just starts turning right. Could I have a bad ram? Not sure how these steer, haven't looked at it yet but feels like there is no direct link from the steering wheel to the wheels.
Thanks ~ Phil
/ New TC35 Owner #12
Not sure I can help on either issue. Is it possible the switches are for a work light(s)? Sometimes there's a "cruise control" for the hydro, but that's usually on the dash.
It's not uncommon for a tractor to drift some. Have you checked the air pressure in all the tires?
/ New TC35 Owner
I haven't checked the tire pressure but none appear slack and when I say drift I don't mean the tractor drifts, I mean the steering drifts, IE if I did not correct the wheels keep turning more and more to that side it would eventually end up doing a tight circle....
/ New TC35 Owner #16
On mine when you initially start the tractor it will be in the turtle mode. You have to manually "rock" the switch to change to the rabbit mode.
/ New TC35 Owner
Thanks, that would make sense why it didn't go very fast.
Thank You ~ Phil
/ New TC35 Owner #18
And there should be a mechanical range selector on your LH side. So - two mechanical ranges x two electronic ranges = 4 ranges.
/ New TC35 Owner #19
And you can also likely switch ranges with two buttons on your loader joystick (if so equipped).
/ New TC35 Owner
Yes I have an FEL with a joystick and it does have buttons on it, I was assuming that was for another hydro control, so those are electronic speed control too, interesting.
So is it OK to change speeds with the electronic switch while moving? And yes I am aware of the mechanical speed control lever.
Thanks ~ Phil
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
2020 Kubota M5111D 108HP 4WD Agricultural Tractor (A59228)
2020 Kubota M5111D...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
Chemical Containers Tank (A57148)
Chemical...
2018 Nissan Pathfinder SUV (A59231)
2018 Nissan...
