Hydo leak in 225
/ Hydo leak in 225 #1
MESSMAKER
Bluegrass,KY
DK4710SE
As many of you know I am in the middle of an engine rebuild and have the tractor in half. I thought I would see if I could dry up a hydo leak I have had for 2-3 years.It only showed up when the motor was warm and was barely visible after it cooled off. It seems to be close the to output shat that is about a foot forward of where the tractor splits. I am guessing it is a seal or O-ring but not really sure. Anyone have any ideas on how to proceed.
/ Hydo leak in 225 #2
I need more clarification. I am thinking tractor splits between engine and clutch housing. I don't understand a hydro leak at that point, especially a foot forward. I know I am not understanding something correctly. Maybe you have it split at the rear of the clutch housing?
/ Hydo leak in 225
I guess to be correct it would be behind the split. sorry for the confusion. It was in the center of the bottom about even with the floorboard.
/ Hydo leak in 225 #4
The hydrastat housing bolts on to the rear of the clutch housing. That housing should be dry. In the bottom of the hydrastat housing is an open drain hole around 1-1/2 to 2" od. I have a small leak at that point. My research on the drawings leads me to believe that leak could be a loose line fitting, oil seal on 4 wheel drive shaft, seal on hydro unit, etc. Just seems to be many places that could leak up in that hydro pump case. Yours may not even be coming from there.
/ Hydo leak in 225
I had thought about the seal on the 4 wheel drive shaft. It is in the right area.
Any idea how much labor is involved with removing the shaft and replacing the seal?
/ Hydo leak in 225 #6
I have not replaced the seals on my driveshaft but did remove it to replace my engine pan. Wasn't that difficult. Just remove a couple of bolts on the cover, collapse them together, remove a roll pin at the rear spline coupling, slide the couipling forward and out she comes. Might want to consider new o-rings for the cover.
Looking at the parts list indicates two front wheel drive shafts. The one inside the cover being one and the other comes out of the transmission and through the hydrastat housing. The seal is actually on the back side of the hydrastat housing and could not be changed without pulling the housing. Would attach pictures if I could. You can go the this sight and look at it. Bobcat Genuine Parts Catalog – Official Bobcat Company site
/ Hydo leak in 225
Got estimate from Bobcat. Have to split the back part of the tractor to repair leak . Looks like about 2 grand. Anybody interested in a kidney?
/ Hydo leak in 225 #8
I think I would set a pan under it to keep the floor dry. :D
/ Hydo leak in 225 #9
Since you have the tractor split you may want to take a look at the HST pump. There have been cases were the gasket between pump case halves is getting distorted and leaking. I'm assuming you see the leak coming from the inspection hole in the bottom of the HST case? Only a couple more steps to remove the HST case and inspect.:thumbsup:
/ Hydo leak in 225
Motor is back running fine but could not locate the leak until the tractor was running. looks like it will have to be broken further back near the hydro to get to the problem.I took it to my local Bobcat dealer who is good, but by no means cheap. Looks like $300 in parts and 12-14 hours labor. I am running out of time before I need it so I am going to bite the bullet.
/ Hydo leak in 225 #11
Guessing most of that $300 in parts would be for fluid and filters. Would be curious what parts they will change?
/ Hydo leak in 225
I suspect the part that causes the leak will be in expensive. I am sure they will replace gaskets when they break it apart. Hydro filters and Bobcat fluid will be the costly part.
/ Hydo leak in 225
I am having a hard time catching a break. I picked up my tractor after having my hydraulic leak fixed. They found 3 separate issues so I am glad I got it done. I watched them start it up and they brought it out to my trailer. I loaded it and headed home. When it came time to take it off, I got nothing. I suspected a safety switch so I checked them out. I got it to fire up after about 15 minutes but could not really determine what it was. I took it back to Bobcat to see if I was missing something simple. 45 min back to the dealer to find that they could not isolate the problem either. The best guess was PTO lockout switch or hydro pedal neutral switch or a faulty wire in these areas. I am starting to wear thin on these repairs after spending over 5 grand in the last 6 months.
/ Hydo leak in 225 #14
Wow! Would you mind sharing the 3 issues they found?
/ Hydo leak in 225
O-ring was pushed out of steel line somewhere inside,seal on drive line was leaking, a valve had to be resealed and front hydraulic line was a bit loose on front axle.
/ Hydo leak in 225 #16
Thanks for sharing. I have a small leak coming out that bottom vent hole but until it gets worse I will just live with it.
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
20' Reids Trailer (A62613)
20' Reids Trailer...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
2011 JOHN DEERE 710J BACKHOE (A65053)
2011 JOHN DEERE...
New/Unused CFG Industrial NT18K Mini Excavator (A65583)
New/Unused CFG...
