4 wheel drive question
/ 4 wheel drive question #1
RedFirstGen
Finger Lakes NY
Mahindra 4035
On a couple different occasions lately when I've gotten my 4035 in situations where it's been real slick/slippery/snowy and needed 4 wheel I've noticed one front wheel spinning/working and the other doing nothing. Any thoughts? Thanks
/ 4 wheel drive question #2
The front differential is not limited slip. So if one wheel has no traction, that's where the power goes.
/ 4 wheel drive question #3
Second that. The "diff lock" only locks the rear differential. If the front was locked the steering would be difficult and it would be hard on the front axle and drivetrain components.
but it will send power to both front wheels at the same time if need be?...
/ 4 wheel drive question #5
In a perfect world, assuming that both wheels have equal traction/grip, the diffential will split power equally to each axle. In real life, it works most of the time. Did you ever notice that the free wheel spins twice as fast?
/ 4 wheel drive question #8
It's very uncommon to have a limited slip or "locked" front axle. The steering axle has extra parts that allow for turning but also make the axle weaker and more prone to failure. The other reason, as described in the video, when turning the wheels need to travel at different speeds. If it's locked it makes turning more difficult.
In Jeeps or other extreme off road/rock crawling vehicles they typically have a differential that can be locked and unlocked as needed.
/ 4 wheel drive question #9
Some of the larger Ag 4-wheel drive tractors have limited slip front axils, in some of the Kubotas for instance.
/ 4 wheel drive question #10
Anytime I've had a front wheel spinning (usually the case; almost never have a rear wheel spinning), I've applied the diff lock and stopped the spinning.
Ralph
/ 4 wheel drive question #11
Ralph
What an interesting coincidence.
Maybe a case where rear differential lock gets tractor moving again so fronts wheels don't appear to spin as much?
Or are you saying you have a front axle differential lock?
/ 4 wheel drive question #12
This is another video. Well worth watching. You can skip to about 2:00 if you don't want to watch the intro. This is a very old video, but it really lays it all out and assumes you know nothing to start with. I think this is truly the best video to explain differential action.
How Differential Gear works (BEST Tutorial) - YouTube
/ 4 wheel drive question #13
Think of power being put to wheels like water. It takes path of least resistance. So, in a open diff truck that will spin one tire (least traction) you can set the foot parking brake to create resistance to the spinning wheel thus giving some power to other wheel. As said most 4x4 daily drivers are only 4x4 when all tires have traction. Unless a device is added to limit spinning.
/ 4 wheel drive question #14
If you have time and you want to read thru this, I will outline some "scenarios"
Lets start with a normal 2 Wheel drive vehicle. This could be a car, or truck or even a 2 Wheel drive tractor.
Lets say you have one tire on a solid surface like concrete or dry asphalt. Now the other tire is sitting on glare ice with a little water on top, or some really slick mud. What happens when you attempt to start the vehicle in motion? Why doesn't it move forward, and why does the tire sitting on the slick surface just spin"? Why doesn't the tire sitting on the perfectly dry surface with good traction move the vehicle forward?
Here is why. Imagine if you will the drive shaft coming from the transmission has a gear called the pinion on the end, that meshes with the ring gear that is hard bolted to the differential frame. Also on this differential frame is either 2 or often 4 spyder gears. These spyder gears are attached to the differential frame by "jackshafts" or "stub shafts".
These spyder gears mesh with the two bevel gears that are on the ends of the axle shafts that go out to the wheels thru the axle tube. As the ring gear rotates as it is driven by the pinion and therefore the differential frame rotates the jackshafts rotate, BUT the spyder gears DO NOT rotate on their shafts, they just rotate and push against both of the bevel gears (remember that are on the ends of both of the axle shafts) and in pushing against them equally, both of the axle shafts turn and of course the wheels and tires turn and the vehicle moves. Whew! that was a mouthful.
This all happens above if and only if the traction applied to the tires is equal. In other words going down a straight dry road. The spyder gears DO NOT rotate on their shafts. Those nasty little spyder gears don't even have bearings, just bushings because they don't rotate a bunch.
When you go around a corner, the traction is unequal. and the spyder gears rotate on their shafts which causes the outside tire to go faster than the inside tire.
When you have one tire on a slick surface, the spyder gears rotate real fast on their shafts, so fast that if you persist in spinning the tire on the slick surface, the spyder gears will eventually overheat their bushings on their shafts from the high speed rotation. By the way your spinning tire is going twice as fast as a speedometer would indicate. So if it says 120 mph, your tire is frying at 240 mph. And your spyder gears will eventually turn blue. (don't ask much more about this)
So your "2 wheel drive" vehicle became a 1 wheel drive vehicle with the one wheel/tire on the slick surface doing the rotation. But since is is just spinning, you might as well have a 0 wheel drive vehicle. Pretty neat huh? 2 equals 1 and 1 equals none!
Now lets multiply our drive system by 2. So now we have a 4 wheel drive vehicle So they say...:)
Now place one of the front wheels/tires on the slick and one of the rear wheels/tires on the slick, and what happens? Same as before the 2 wheels with the least traction spin and the other two on the dry surface don't move. So now 4 equals 2, and 2 equals no forward motion either. Pretty cool huh?
So what can we do to get this tractor moving off of the slick stuff? We can one of two different things. We can apply the rear differential locking mechanism which will solidly lock the two REAR axles together and now we have 3 moving tires. AND guess what ONE of them is on a solid surface and the tractor will move forward. OR we could apply a braking force using our split brakes (not all tractors have split brakes but many do) to the rear wheel that is spinning. When we apply this braking force to the rear spinning wheel, this slows down the axle shaft and gives those spyder gears something solid to push against and stops their rotation on their jackshaft, which in turn allows force to be applied to that other axle shaft that is attached to the wheel/tire on the dry surface and it begins to move. So you wind up with a 3 wheel drive system. The only time you have all 4 wheels pulling equally is when the traction surface under each tire is equal.
If you are in a car or truck and you are stuck you either have some sort of many different locking mechanisms built into the rear end or the newer "traction control" which does independent braking when a wheel sensor indicates wheel spin OR if you have none of this, you get out and push or call a tow truck.
So remember 4 equals 2, 2 equals 1, and 1 is none. Happy tractoring. :)
/ 4 wheel drive question #15
Ralph
Me too
Great responses. Thanks. I learned some stuff for sure. The one very practical thing I learned is to remember to use the differential lock. Forgot all about it. Duh.
/ 4 wheel drive question #17
Anytime I've noticed a front wheel spinning (usually the case; almost never notice a rear wheel spinning), I've applied the diff lock and stopped the spinning by locking the rear wheels together.
Ralph
Fixed it for you :thumbsup:
/ 4 wheel drive question #18
For those saying you have a front wheel spinning while the back wheels are not spinning, how is that possible? Both rear wheels are still, and only one front wheel is spinning?
/ 4 wheel drive question #19
It's not possible unless something is broken....... but it is easier to notice the front slipping since they spin faster (at least in terms of rpm), hence the incorrect belief that the rears are not spinning as well.
/ 4 wheel drive question #20
Ya if front is spinning and not either rear something is broken bad.
2016 Chevrolet Cruze Sedan (A61569)
2016 Chevrolet...
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2019 GENIE GS-1930...
2022 CATERPILLAR 289D3 SKID STEER (A62129)
2022 CATERPILLAR...
2017 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2017 Peterbilt 567...
