I think it depends on the school and what their goal was. To TS and install or fundamentals? I never went to school, but worked for company installing boilers and furnaces. I bent tin, sweated copper ect. We had techs come and dial the natural gas in. Though some of plumbers felt they could do it too, but it was factory warranty thing. To trouble shoot and install you don't need theory. That is why they have tech schools and engineering.
Maybe yours covered it.
When it is around 0 out, I do leave it at constant temp, figuring in that case it is more efficient. Again all of this is from bowels.
Below are not technical articles, so maybe you are right. But the first 3 sites i came to disagree with you. Googled how low should I turn down my furnace.
Heat pumps,are different. But we don't tend to use those up here. Unless you are a hippie and want to save the penguins.
turn your thermostat down
7-10 degrees.
Turn Your Heat Down, Not Off, to Save On Your Heating Bill
A
10-degree drop could be 10 percent savings.
Common heating myths that can raise energy bills - Chicago Tribune
When your home will be empty for 8 hours or longer, set your thermostat 5°-8° higher in the summer and 1
0°-15° lower in the winter.
When you get home, set the thermostat back to your comfortable setting.
Doing so can save you 5-15% on your yearly energy costs, according to the U.S. Department of Energy.
3 Dumb Things You Do With Your Thermostat That Cost You Money - Minneapolis Saint Paul Plumbing Heating Air
