Pallet fork length
/ Pallet fork length #1
TNhobbyfarmer
Middle Tennessee
Kubota L3430 Polaris Ranger 500
I am going to order a set of forks from Titan. They offer 36, 42 and 48 inch lengths. I am going with either 42 or 48. My tractor is a Kubota L3430. My inclination is go with 42" for the purpose of not having the extra length out front to negotiate around buildings etc. Since this will be my first set of forks, maybe you guys can pitch in with your thoughts, recommendations, etc.
/ Pallet fork length #2
42" is the best all purpose I think. 36" is too short and 42" lets you pick up pallets without having to worry about sticking out the other side.
It is easy to make extensions with channel iron for picking up things that are big but relatively light like pickup beds.
/ Pallet fork length #3
I went with 48" and use them for pallets and tree logs, lifting things with chains like air compressors and tables etc. I work in close quarters sometimes. I never once though to myself, "Gee, I wish they were shorter."
/ Pallet fork length #4
Count me in the 42" category. They handle all pallets, skid boxes, and standard reusable liquid totes and who needs extra length going along for the ride or sticking out the other side to catch on things.
/ Pallet fork length #5
What I use my pallet forks for. I have never measured what there length is. I know there about 6in shy of covering a 4ft round bale. So 42in? I often wish they were longer but these get the job done.
I love my forks, never even had the bucket mounted, I have been able to do EVERYTHING with forks and a rear blade lol. Snow removal, hauling, light ground engagement, feeding cattle mineral tubs (250lbs), feeding cattle with round bales (700lb-1500lbs) ext. that big bale was easily over 1000lbs.
If I had to buy them for what I use them for, I would go with 48 but 42 should be just fine.
I would get one with a nice tall guard like mine or taller, saves crap from falling back towards the tractor.
/ Pallet fork length #7
It depends on what you will be using them for. I started with 24", no pallets, mostly brush.
/ Pallet fork length #9
Count me in for 42" forks. They work great for me for all the previous reasons.
/ Pallet fork length #10
I have the 42 inch Titan forks. I don't know if it's just me, but I have had them come disconnected 4 or 5 times and fall to the ground. No damage, always when nothing was on the forks. I bought them because the price was right, but I would not buy another one or recommend them to anyone, because I Don't fully trust them anymore.
/ Pallet fork length #11
See this thread. Others with TITAN forks had to add a shim because forks weren't made to spec. Adding this shim will probably tighten up your forks to fit your QA properly.
http://www.tractorbynet.com/forums/attachments/337508-pallet-forks-disconnect-fel-quick.html
/ Pallet fork length #12
Yeah. But look at the size of your tractor!
Yep, but it will handle bigger, so I made the brush fork 54" wide, with 48" long tines:
It will lift a pallet. :D
/ Pallet fork length #14
Mine are 42"s and that's what I'd buy again.
/ Pallet fork length #15
I had 48 sold them and bought 42. With the 48 I punch a few holes in the barn
/ Pallet fork length #16
I think your mount for the forks was made out of specs. Titan did have an issue with this and has been corrected. I would contact them.
/ Pallet fork length #17
I read the thread. Can anyone tell me if Titan has since corrected the issues detailed?
Yes the problem has been corrected. I have a pair of 42" forks and have no problems. IMG_0594.JPG
/ Pallet fork length #19
Also consider visibility. My 42" are hard to see at ground level when spaced for a standard size pallet. I think I could just see the tips over the hood if they were 48".
/ Pallet fork length #20
I have found myself almost standing up to see my 42s, which poses a prob because the tractor won't move unless the switch is triggered in the seat.
KBH Tender Trailer (A56438)
KBH Tender Trailer...
UNUSED WOLVERINE SB78-78" ROCK BKT (A62131)
UNUSED WOLVERINE...
2024 John Deere 6R 130 Tractor Loader (A63109)
2024 John Deere 6R...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61568)
2016 Ford F-150...
UNUSED RAYTREE RMDM70 - 70" DISC MULCHER (A62131)
UNUSED RAYTREE...
2003 JOHN DEERE 310SG BACKHOE (A62129)
2003 JOHN DEERE...
