Anyone know the correct color grey for Kubota front end weights?
   / Anyone know the correct color grey for Kubota front end weights? #51
Thank you for taking the time to help me out. After checking notes, I see what Kubota did have figured it out. Altering my current bracket is probably not a good idea so I'll just order the part. This really helps a lot because weights won't stay on but only come on for tillage and that can occur on short notice when I would rather not be wasting time with the bracket. This will work. Thank you.
Good call, I think you will be best with the right part installed.
   / Anyone know the correct color grey for Kubota front end weights? #52
Wow, I better try to hunt this down. I had one dealer tell ne it was the same color as the frame but ROPS gray is so close. Thanks and I'll check it out. I appreciate the tip.
I went and checked, and I did use the ROPS gray 7000. These weights had lots of surface rust when I got them and I have had them on 3 different M Tractors. I think the last time I painted them was around a year or so. I like being able to quickly remove and reinstall as the need arises. I normally have the loader off when I bushog which is mostly what thie tractor is for.
After an email to the best Kubota parts guy I know, he checked and double checked but he already knew. ROPS gray is only for the ROPS and that's why it's only available in spray cans. No quarts or gallons because only of one small dedicated use for the ROPS. That's also why it's called ROPS Gray.
Front end weights are painted Kubota Dark Gray, the same color as the frame and engine. Some were gloss and some were not. Almost all were gray, post 1989. Available in spray, quart and gallon.
I'm going with the Gloss Dark Gray just because, but if I painted one set Gloss Dark Gray and another ROPS gray, few of us would notice.
   / Anyone know the correct color grey for Kubota front end weights? #54
Sounds like a good plan!
   / Anyone know the correct color grey for Kubota front end weights? #55
They are grey and I want to repaint some for an M7040. It could be Kubota ROPS Grey, Kubota Dark Grey Enamel or Kubota Dark Grey Semi-Gloss. Trouble is I don't know which and can't seem to find an answer. Does anyone know? It's important to me that I get the correct OEM color.
Maybe this chart will help.
All I can say is that I'm quiet amused (in a good way) by how this thread has advanced. :)
You've gone from "It's got to be 'correct'!" to "Bugger it, I'll just choose a colour and go with it."
Good on you Mate for handling your OCD condition... fight the good fight!
[And I hope that you can sleep at night. :laughing:]
I'll post a pic when I'm done and I think you'll be amazed at how nice they come out.
   / Anyone know the correct color grey for Kubota front end weights? #57
Six you probably wont like this but....
I have been looking for Kubota 55 lbs weights for a couple years on craigs list, nothing. Over this winter, I found (2) people selling 3 weights each. Bought a set for $100 and $125. You know what a dealer will charge for 6 weights, 2/3 times that. One set looked like an old Kubota blue and another grey. I like the old stuff, they are made right. Knowing they are going on an Kubota orange 3pt hitch, I painted them Kubota orange because of abrasions and scratches, should be hardly noticable.
   / Anyone know the correct color grey for Kubota front end weights? #58
The before pic;
I took the rust off, primed and painted them.
HTML:
Actually, I like them a lot, especially that weight. Around here, that weight sells for full price, assuming you can find any. Orange II is also a very good looking color so that's good too. We have some leeway with weights which is why I think it's OK for me too go rogue and paint a slightly different color.
How about a picture and arrangement of what they are going on? With weights that good looking, I'll bet the tractor is too.
   / Anyone know the correct color grey for Kubota front end weights? #60
:thumbsup: I just had to open this thread to see how "what color grey are front end weights" could go on for 58 posts. Fight the fight! :laughing:
2015 Chevrolet Silverado 3500HD 4x4 Crew Cab Service Truck (A53422)
2015 Chevrolet...
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
UNUSED FUTURE FT-CW59 59" HYD COMPACTION WHEEL (A57193)
UNUSED FUTURE...
XCMG CV83PD (A53317)
2005 GMC C8500 Utility Flatbed Truck (A55852)
2005 GMC C8500...
UNUSED JCT HYD VIBRATORY PLATE COMPACTOR (A57193)
UNUSED JCT HYD...
