Mini Ex angle blade
/ Mini Ex angle blade #1
oldafretired
North Idaho
Kubota L3901, MX5800, U55
I'm going to order a U55 soon. Is an angle blade worth an extra $2500 over a regular straight blade for just doing work like digging out stumps on my property?
/ Mini Ex angle blade #2
For the kind of money you will spend on a U55 the answer is .....YES!
If you don't get the the angle feature, you will curse the day you made the decision to not do so.
I assume you will get a thumb also?
/ Mini Ex angle blade #3
Yes, Yes, Yes....
I use the angle blade on my cat all the time. It's invaluable!
Sounds like an angle blade is a worthwhile option.
Yup, definitely getting a thumb and quick connect bucket.
How is the ripper attachment that Kubota makes for the U55 and KX057? Has anyone used one?
Is a 24" bucket a good one for general use?
/ Mini Ex angle blade #6
It all depends on what type of ground your working in. Hard rockey soil will need a narrow bucket to get the maximum breakout force. If the soil is loamy and not that rocky, the bigger bucket is better.
I need both and use both a lot.
Thanks guys. I guess I'll get a 24" to start and get a 12" and ripper later.
/ Mini Ex angle blade #8
Get it now with the machine . Might be a little easier on the wallet ?
I'm already going to spend almost twice what I initially planned so I think I'll wait awhile to get extras. It will also give me something to buy later on. :)
/ Mini Ex angle blade #10
Good choice. That combination will be handy. If I were to go with only one bucket, I would compromise and get an 18" bucket. But a 24" and a 12" bucket is even better.
Some places sell rippers with teeth like coarse saw blades. Would they be any better than a regular ripper in breaking roots around a stump? Is there an actual sawing motion pulling the ripper though roots?
/ Mini Ex angle blade #12
I guess there could be if you wiggle the levers correctly .
/ Mini Ex angle blade #13
When I got my KX121 I wheeled and dealed with them to throw in the 12" bucket, they manipulated the numbers by dropping the price on the excavator to add the discounted bucket to make it all come out to the original price. I would try that at the time of your sale. It is hard to come back and get a good deal later. I switch back and forth between the 24" and the 12" all the time. It is so worth it. I wish I had gotten a clean out bucket at that time. Now it is hard for me to justify a thousand bucks for one.
/ Mini Ex angle blade #14
I would spend the $2500 on a ripper and ditching/clean out bucket vs the angle blade. I would also measure the width of the thumb to see how narrow a bucket you could use (for me that's 16-18") and get that also. I bet the cost would be pretty close and those items will be much more useful than the angle blade IMHO. (I did just that!)
Thanks for all the good advice. They're going to give me a price break on the ripper so I'll go ahead and get that. Stump removal is my main objective right now. I think I will look for a 36" bucket later on if I need a bigger bucket. Hopefully I can find a used one.
What is a clean out bucket and what is it for? Thanks.
/ Mini Ex angle blade #16
A cleanout bucket is just a (usually) toothless bucket, as wide as the particular machine can handle - used for cleaning out ditches -
Do you have any links/pics of the "saw blade" ripper? That's on my list of "tuits" for my 580B, and for just what you intend to use it for - somebody else might have a better way than what I thought of. If so, please post... Steve
Thanks! I guess I won't need one of those buckets.
Here's a couple of links:
SABRE TOOTH STUMP & ROOT RIPPERS
root_ripper
/ Mini Ex angle blade #18
Thanks, the first link isn't quite what I'm looking for and I had the second one already - that's more what I'm envisioning, except I'll probably do the inside edge of the ripper smooth to avoid stress cracks, then ADD teeth out of AR plate "dominoes" with the cutting edge beveled with plasma for more aggressive teeth than just square cut - the "dominoes" will be overlapped maybe 3/4" so each "tooth" sticks up, teeth about 1/4" wider on EACH SIDE than the body of the ripper.
Otherwise very similar to the second link, but DIY cost should run maybe $200-250.
Thinking when I build my thumb I may make extension "wings" on it for a wider grip when using it with the single ripper, so I can have better control when moving/stacking entire trees with just the ripper and thumb... Steve
2015 John Deere 35G Mini Excavator (A62613)
2015 John Deere...
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2016 Chevrolet 2500 HD 4WD (A63689)
2016 Chevrolet...
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
2023 Deere 325G (A60462)
2023 Deere 325G...
