In my opinion, all 3 point post hole diggers are the same except the auger teeth. The differences in the gear boxes are minimal and something you'll never have to worry about unless you get an oddity lemon type of mistake, but overall, they are all pretty good. Same thing with the driveshafts and augers. The big difference is in the teeth!!!
Lenibach line has a plate of metal with a chisel edge and a point to cut through the clay. If the clay is soft, like in spring after the rains, it's fine. If you try to drill a hole in August, it just spins and spins until the metal wears off, then spins some more.
Speeco has interchangable teeth and tip, but they wear out quickly and also like so spin on hard clay. If you dig a little, add water and come back the next day, it will dig just fine most of the time. But eventually, I couldn't find any teeth when I really needed to drill about 20 more holes to finish off a fence, and no time to get it done. That's when I decided to try the Country Line auger from Tractor supply.
The cutting teeth and tip are very aggressive. It's like going from a butter knife to a steak knife. The difference is night and day.
