Good morning!!!!
   / Good morning!!!! #56,291
67°F and .01 inches rain since midnight
Wife's birthday today. I'll make her breakfast, take her out later.
Tenants moving into the Cottage today for 3 months. Relocating from FL.
Got news we may lose our internet. :( Could be interesting next few days.
Be safe
Have a great day.
   / Good morning!!!! #56,293
Be safe
Have a great day.
Happy BD to your lady.
   / Good morning!!!! #56,294
Guy about a mile down the road from us was mowing his lawn when I drove by yesterday evening on the way home form work, hawkeye08. Gave me one of those "Holy Cow!" moments.
I need to finish servicing my mower among all the other projects.
   / Good morning!!!! #56,295
VW used a printed film wiring harness inside the instruments if the film cracked without exterior stress, that was sure a bad engineering solution.
Is this normal for modern instruments or someone's better idea?
I can provide only a few data points. The lamps in both '93 and '95 BMW air cooled motorcycle instrument housings use the same kind of blue film ribbons for the circuits as the '87 van. And the '85 k-bike has it, too. All of them are brittle with age, and the k-bike has several jumpers made from insulated copper wire to fix cracks in the traces on the circuit ribbon.
The repair kit I found moves all the discrete components (diodes, resistors, voltage regulator) to hard circuit boards that attach to pins on the instrument housing. Insulated wires in the form of mini wiring harnesses replace the ribbon circuits, and the wires terminate either in a header that slips over pins on the circuit board or with an eyelet terminal that slips over a threaded stud on the instrument housings. Looks pretty bullet proof.
I hate to think what's going on under the dash of a modern vehicle. All of them are designed to be cheap to produce without any regard for maintenance or longevity, and rely heavily on components unique to particular models and years. Since computers are involved, and computers evolve in generations lasting only a few months, it seems unlikely that repair components will be available in ten years, let alone 30. And few of them will have the cult status necessary to support the cottage industries that keep the older vehicles on the highway and make using one as a daily driver possible.:2cents:
   / Good morning!!!! #56,296
Flexible circuits have gotten better in recent years, but they're still not very reliable over time. Those materials simply do not stand up well to the ravages of time/temp/humidity/movement. Nice that you found a solid solution, RNG.
   / Good morning!!!! #56,297
Thanks Billy.
It's doing just fine, stored over in the barn presently ... but I do need to do some work on the tractor side QA adapter. It appears that the material Titan supplies is a little on the thin side. Ended up tearing.
Hey RS, Little curious as to what part tore on the adapter? Were you using the grapple? Will make sure to let our qc department know. We like to document these instances to make improvements on our products when we can.
   / Good morning!!!! #56,298
Apparently, in Clinton County IL, if there is damage over $1500, a report is required. There was no property damage other than his car. Having seen pictures of the car, it will definitely be over $1500 ... on a car we got for $1200.
Well, we got the quote for the repairs to junior's car, and using used parts it's just under $1K. While I'm still not happy about that, I suspect it will be instrumental in the dismissal of a couple of over-zealous charges.
   / Good morning!!!! #56,299
Got ears lowered.
Also managed to go get an eye exam scheduled and done and order new glasses.
It's been a little over seven years since I've had the eyes looked at and possibly ten or more since new specs.
Mixed report on the eyes ... either the near or far vision had improved slightly, and the other one (near or far) had gotten slightly worse. Left eye was worse than the right. Evidently no other problems.
Will be nice to have a pair of glasses that aren't all pitted up from grinding dust and have no cracks in the lenses ... :laughing:
2012 Honda Civic Sedan (A56859)
2012 Honda Civic...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A56859)
2004 Fleetwood...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
HOMEMADE JOHN DEERE 98"X27' DBL AXLE HAY TRAILER (A58375)
HOMEMADE JOHN...
2017 CATERPILLAR 259D SKID STEER (A52709)
2017 CATERPILLAR...
2014 Bobcat 72" Rotary Cutter (A57149)
2014 Bobcat 72"...
