Backhoe zerk fitting thread size
/ zerk fitting thread size #1
TJPhilips
Linden,MI
Kioti CK3510
Anyone happen to know the thread size for zerk fittings used on the Max 25?
/ zerk fitting thread size #2
This may help...
Zerk Fittings / Grease Fittings
The only 2 sizes I have ever used are.....
Grease Fittings / Zerk Fittings
AS Grease Fittings 1/4"-28 Taper Thread Fittings
1/8" PTF Grease Fittings 1/4" PTF Grease Fittings
1/2" NPT Grease Fittings Drive Type Grease Fittings
/ zerk fitting thread size #3
I know absolutely zero about zerk sizes. I took the old zerk down to Napa and bought a handful that were the correct thread size. Easy solution.
/ zerk fitting thread size #4
Tough to say. The loader is probably made in USA and the chassis isn't. The tie rods etc were probably sourced so who knows what they are. Some could even be press fit. I think you will need to take the offender to an auto parts store to match.
Or go this route and hope-
Swordfish 41030 SAE Grease Zerk Fitting Nipple Assortment, 110 Piece Amazon.com: Swordfish 41:( SAE Grease Zerk Fitting Nipple Assortment, 11 Piece: Automotive
Swordfish 41271 Metric Zerk Grease Fitting Assortment, 110 Piece Swordfish 41271 Metric Zerk Grease Fitting Assortment, 11 Piece - - Amazon.com
/ zerk fitting thread size #5
I keep a box each of SAE and Metric assorted zerks from HF on hand at all times, saves running around for only one. NAPA has the kits also. The press fit ones are different problem, haven't found one on my BX or any implement yet.
Ron
Ron
Thanks for your advice
/ zerk fitting thread size #8
Dont forget there are some push in zerks that look like treads but are not. I had no idea when a customer brought them in. Im used to tread on.
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
40 (A52708)
40 (A52708)
2025 GPS Equipment Trailer (A56859)
2025 GPS Equipment...
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
