Buying Advice ANother what do i do
/ ANother what do i do #1
retiredolman
adams wi
ford
Im tired of tractors older than myself ...... I have a choice between a 09 ct235 bobcat for 13000 with 1600 hrs and two remotes
and a 2014 ck35 kioti.....The bobcat is a clone...with only 60 hours for 17000. both have Q/A buckets on FEL...
The Kioti does have a couple years left on power train Warr. but is that worth 3000 bucks
I have about three food plots...one 5 acres...45 acres wood lot to maintain...and here in central wi i have black sand for soil. So i think i need the weight these tractors provide as i see a 2015 kbota b3350 with low hours for 16500 with Fel NO REMOTES....
All the dealers are about the same distance away and seem as equals in experience and reviews
So lets hear ur Opinion.....
/ ANother what do i do #2
Do you foresee a NEED for the remotes?
My M4700 came with 2 remotes in 2013, I've yet to use them.
/ ANother what do i do #3
the bobcat should be without all the new emissions junk that has caused tons of problems in all brands where the 2014 kioti should have them . I would take the bobcat based on this item alone or wait a few years till the companies get the bugs out of this pollution crap . Other than that either 1 should be a great unit .
/ ANother what do i do #4
Just to clarify, the Bobcat was actually made by Kioti for Bobcat, so it's virtually the same tractor as that CK35. Both are solid, well-made tractors, with lots of work potential if they are in good shape.
The 2014 CK35 would have the new emission plumbing, but I've not heard about that particular model having problems due to the emission controls. The Kioti owners here would have better knowledge and maybe will add a comment. Conversely, I would have some concern that the CT235 has only 60 hours of use in 8 years, so it has been sitting around an awful lot. Generally, that's not good for equipment, as hoses, seals, linkages, etc., can become brittle or seized up over time.
/ ANother what do i do #5
Pricing seems high on both, especially the BobCat, Offer Tops, 10K. I'd Keep shopping! Consider Craig's List.
/ ANother what do i do #6
Oh NO!
I must be facing BIG trouble!
Each of my 3 old Fords sit for about 10 months every year (with battery tender attached).
Now I learn that "sitting around an awful lot" is about to kill them!
I have owned one for 46 years, another for 30 years (but is 47 years old), and the 3rd for only 3 years, but it is 29 years old, and has only 1000 hours (I use each of my Fords less than 15 hours per year).
They are not rotting away yet!
/ ANother what do i do #7
Oh NO!
The Bobcat is stated to have 1600 hours, about 1/2 its useful life.
Yes i do use the ones on my ford 850 for a wood splitter, rotavator and the wagon and spreader i get each year for lime and ferilizer from the co-op
/ ANother what do i do #9
Little bit of confusion?
In the OP first sentence he describes the Bobcat as having 1600 hours.
In the second sentence he describes the Bobcat as a "clone" with only 60 hours.
Am I missing something here?
Im sorry.... the Bobcat is a Clone of the Kioti and the Bobcat has 1600 hours.
/ ANother what do i do #11
Oh NO!
Well, you got me there! :thumbsup: But you know what they say concerning staying active instead of sitting around all the time. I know that's true for an old coot like me, and I've concluded it also applies to equipment in some degree. Actually, I've got a '49 Farmall M that mostly just sits, like your Fords. And guess what? It always did leak some (when you get old, that happens), but there are more leaks every year I have it.
/ ANother what do i do #12
Agree. Price is too high for both. 10 grand might be a little low on the bobcat, but not far off. Kioti should be worth no more than 14,500, even at the stealership.
/ ANother what do i do #13
I don't think the CK35 has the final tier emissions and should be the same machine as the bobcat with a different loader. Out of what is described I would most likely be looking at the Kioti or Bobcat depending on how much the seller would come down on the price, one of them would be coming home with me.
/ ANother what do i do #14
The difference between 60 and 1600 hours would be ten years or more for me. Easily worth $3k. You were asked - do you need the remotes?
Id like to thank all that replied.... I ended up with a Kubota b3350 2014 that was priced in the middle of the two..delivered and tires loaded.....
YALE FORKLIFT (A63291)
FIRD MIXER TRUCK (INOPERABLE) (A67714)
FIRD MIXER TRUCK...
2015 Ford Transit Connect Cargo Van (A64556)
2015 Ford Transit...
2012 INTERNATIONAL PAYSTAR 5900I (A67714)
2012 INTERNATIONAL...
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
2019 PETERBILT 567 (A67714)
2019 PETERBILT 567...
