Loader New Grapple Build! Let me know what you think
   / New Grapple Build! Let me know what you think #91
And, perhaps Titan has changed their manufacturing standards but as I recall they were the company that was using 1/8" wall square tube that failed on several grapples. .
Wildcat's 1/8" tube failed on their lower end grapple. I don't recall Titan making one that failed easily. Titan's main issue was the notorious fit problems where they refunded $50 if the owner welded on a shim.
   / New Grapple Build! Let me know what you think #92
Thanks for the correction. Yes, it was Wildcat (?Wildkat) not Titan that saved $10 per grapple by substituting 1/8" thick wall tube for the standard 1/4". My apologies to Titan.
Got the Grapple all painted up and ready to install!
There's my guys there - they help get it all assembled and painted!
Way to go Mario and Esteban!
Also got my cylinder and 3rd function in today.
Got the lines all measured up and hoses and fittings ordered.
It'll be a week or so before the rest of my parts get in, I post some more along the way and of course a video once it's hooked up and running!
   / New Grapple Build! Let me know what you think #95
Super nice work!
   / New Grapple Build! Let me know what you think #96
Very nice work. The bottom looks great. I'm gonna suggest that you consider a bit more bracing on the jaw. What you have will work perfectly for moving logs but if you are using the upper jaw to help rip out brush I think I'd add more steel. Take a look at the upper jaw of the EA Compact grapple. They have the best upper jaw in the industry IMO. My own grapple doesn't have much either but I had to heat/beat/weld in some gussets on the tips that splayed out when clamping on big rocks. I've also lost a hose right at the cylinder due to lack of protection from below (yours is fine). I also wonder if your cross tubing is big enough to withstand the twisting forces that are inevitable when you clamp on an odd shaped object like a rock. Mine has thicker tubing and it is still a bit bent after ten years....nothing that affects function but evidence that more bracing would have been better. Here is a photo of mine for reference (photo when new, it's more battle scarred now) and the rock that splayed out the tips.
I have been wondering about how the clam will hold up.
It's on new so we will see, I will make a new lid if it doesn't hold up well.
Thanks
   / New Grapple Build! Let me know what you think #98
Thanks
The lid basically looks fine it just seems a bit lightly built. Wouldn't take much to beef it up. Another cross tube would help. Also make sure the tips are supported/gusseted.
Thanks
   / New Grapple Build! Let me know what you think #100
Siharman1
Your Grapple build reminds me of when I built my own rifle. I did it just to do it, but would never do it again. I'd buy the gun or have one made to my specs.
I built my own gizmos, not as difficult probably as a complete grapple, but still a lot of fab & design work for one offs., only because there was nothing like it I could purchase. I admit Solidworks is a lot of fun. You must have learned a lot designing the grapple, I hope your are a better welder than I am!
I admire your ambition, but in my old age, I sure try to do only the stuff I can't readily or economically have done for me.
Here is some of my stuff.
http://www.tractorbynet.com/forums/attachments/327912-custom-3-point-attachment-2-a.html?highlight=
http://www.tractorbynet.com/forums/build-yourself/372240-3pt-stuff-your-loader.html?highlight=
http://www.tractorbynet.com/forums/projects/374740-my-wife-wants-gazebo-help.html?highlight=
http://www.tractorbynet.com/forums/...d-hydraulic-clyinders-loaders.html?highlight=
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
2024 John Deere 35 P Excavator (A53485)
2024 John Deere 35...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
2012 BIG TEX PIPE TRAILER (A55745)
2012 BIG TEX PIPE...
