Oil & Fuel SAME Argon 50 transmission oil level check
/ SAME Argon 50 transmission oil level check #1
tzeggy14
Shellharbour
SAME Argon 50
Hi guys,
I'm trying to check the transmission oil level in my SAME Argon 50.
The manual has a diagram that isn't clear in its indication of the level checking point.
I see there's a small (6mm I think) allen-head grub screw right near the top rear of the transmission. I removed it and it seems there is nothing behind it and no oil seeped out.
Is this the oil level checking hole? ie. the one you remove and see if the oil is up to its level?
I'd take a photo, but the tractor is 2 hours away at my farm.
Thanks,
Greg
/ SAME Argon 50 transmission oil level check #2
Probably not many familiar with your tractor, but I'd think the check hole would be the same as the fill hole, and therefore it would make sense that it would be a much larger bolt/plug. ??
My experience has been that the fluid level would be kept at about axle height, not near the top of the trans.
Good luck!
/ SAME Argon 50 transmission oil level check #3
I believe the tranny/hydraulics are the same oil, are you sure you don't have a small round window on the back by the 3 point, to show the level of the oil. The proper level is half way up the window...
DM
Good luck!
Thank you for the reply 1st Duece.
The filler hole is right up above the transmission on these tractors.
Thanks for the reply Sawyer Rob,
Correct about the transmission/hydraulics oil being the same.
No window, it's definitely a plug. Says so in the manual.
You will see what I mean about the diagram!
I might have to have a look this weekend when I go back to the farm.
I'll clean the whole rear assembly up so I can see properly. It's covered in oil/dirt.
/ SAME Argon 50 transmission oil level check #6
You can see the little window on mine, just to the right of the PTO shaft,
You check the level with the tractor level and the 3 point all the way down, AND yes, mines a little low on oil...
SR
SR
Thanks!
I'll check it out on the weekend.
Confirming that mine has, beneath the thick layer of crap it had all over it, a window just like yours Sawyer Rob.
Thank you!
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
KUBOTA BX2380 TRACTOR (A62130)
KUBOTA BX2380...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2018 Chevrolet Colorado Crew Cab Pickup Truck (A61568)
2018 Chevrolet...
