Loader New Grapple Build! Let me know what you think
   / New Grapple Build! Let me know what you think #61
I would really like to know what the final cost will be when complete and operating. I know there is a lot of pride in building something yourself and I have done the same on different things. How much is a new one installed? In comparison to the material and the time spent building it. Still it looks good and you should be proud.
   / New Grapple Build! Let me know what you think #62
I think you'll want one more support centered in the lid to support between the cylinder and the center of the "jaw".
   / New Grapple Build! Let me know what you think #63
Just wondering why you lowered the mount for the base of the cylinder?
First design:
Now, reduced clamping force:
I have added more support. I am not sure I like the looks if it, but I think it is strong enough.
Still deciding if I am going to change the clam supports, but I am running out of material :)
I am proud of it - trying to decide if I want to change the looks of the clam supports.
So far the costs have been as listed below.
All Steel (3/8" plate and schedule 40 pipe) $263.00
Third Function kit $448.99
Cylinder $122.77
Total so far $807.76
I will still need to buy some hoses and fitting about $100.00
So I am thinking around $900.00 for total build - minus the $263.00 for steel I didn't have to pay for.
So i am all in at around $637.00
Not bad considering a decent grapple will cost around $1800 plus shipping without third function mine is in comparison, $122.77
Well worth the effort.
Here are some pictures of the build in progress.
And some more:
And still more:
IMG_0671.JPGIMG_0670.JPGIMG_0669.JPGIMG_0672.JPGIMG_0673.JPGIMG_0675.JPGIMG_0676.JPGIMG_0677.JPG
   / New Grapple Build! Let me know what you think #70
I need some help with the bushing and shafts.
Does anyone have a line on getting those near Houston?
Found the cylinder at Suplus Center.
I am trying to decide between WR Long and Construction Attachments "one touch" kit.
Or just build my own from scratch (with a little help from my friends here on TBN :thumbsup:)
So any suggestions would be nice.
Thanks
Steve
I wouldn't worry at all about bushings. My grapple is twelve years old and has no grease-able pins. The jaw pivots on 3/4" bolts. No grease ever. The threads at the contact points are worn off but it appears that the bolts will need replacing in about fifty years.
Regarding hydraulic controls, I'm a fan of just using rear remotes. I have used diverter valves and rear remotes and I prefer the much cheaper and simpler rear remotes.
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
2012 Chevrolet Impala Sedan (A55853)
2012 Chevrolet...
2016 Freightliner 114SD T/A 4,000 Gallon Water Truck (A53422)
2016 Freightliner...
