Buying Advice If you could only choose hydro or cab what option would you choose for your tractor?
   / If you could only choose hydro or cab what option would you choose for your tractor? #1
bulldog81
Mobile
LS
I'm going to look at LS tractors today. I am thinking about a XR3037.
There is an XR3037C at one dealer with a loader, LMC 5ft rotary cutter, and box blade for $21995.
Another dealer has an XR3037H for $19,500 with just a loader.
Either one can get me a XR3135CH (I don't thing the 3037 is still made) but it's around 25K give or take. That's a little more than I want to spend. I am also going to buy a commercial ZTR or I would spend more.
I am closing on a house with 20 acres on the 17th. Ten acres are cleared around the house. There is 10 acres of woods behind the cleared section. There is already a decent size clearing through the woods with a deer blind and a few established trails.
If you had to choose cab or hydrostat and not both which would you opt for? Pic of the property:
   / If you could only choose hydro or cab what option would you choose for your tractor? #2
For my uses "cab" hands down.I do have both a cab+HST though.As long as the cab has Air conditioning ,just a fish bowl with-out it.I am thinking about moving up in HP so a Cab+manual shift are my only options.
   / If you could only choose hydro or cab what option would you choose for your tractor? #3
My thoughts exactly. I am assuming that Mobile is in Alabama, where it is hot most of the time and cold for you is any temperature below 40F. Cab with air is a must!
   / If you could only choose hydro or cab what option would you choose for your tractor? #4
I too would choose the cab. Looks like you will be doing a fair amount of mowing in the hot summer sun, I don't think you will regret having ac and a radio while doing the work.
Just be alert for tree limbs in the woods.
   / If you could only choose hydro or cab what option would you choose for your tractor? #5
We have both on our 3135, and I wouldn't want to give up either. I guess the only serious consideration you might have is how much time you'll spend with it in the woods. Tree branches and glass are ancient enemies.
Good-looking property. Congrats.
... and welcome to TBN!
Be sure to post lots of pictures when you finally decide and bring one home. :tractor:
   / If you could only choose hydro or cab what option would you choose for your tractor? #6
I've chosen open station for the two tractors I've owned. I live in NE WA state and while it does get hot/summer & cold/winter - we don't have the humidity and I don't use a rotary cutter. I fear the damage I would do to a cab with all my pine trees and I just plain like being out in the fresh air.
However - if I did a lot of bush hogging and lived where its hot and humid - well, that's a different story.
   / If you could only choose hydro or cab what option would you choose for your tractor? #7
3 years from now... whichever you choose... you will wish you had sucked it up and chosen BOTH.
   / If you could only choose hydro or cab what option would you choose for your tractor? #8
When is a manufacturer going to come out with 70-80 HP and HST?
   / If you could only choose hydro or cab what option would you choose for your tractor? #9
Because of your location cab hands down...but than again doing fel work HST sure nice.
   / If you could only choose hydro or cab what option would you choose for your tractor? #10
I chose 3 years ago for a XR3037HC cab with HST and wouldn't be without either. For my uses I want HST for repetitive forward / backward motion without having to shift. Also wanted the cab so I heat in winter and A/C in summer.
I suppose if I had to choose between the two options I'd opt for the cab without HST but I didn't have to.
2021 Fleco DX140 24in Digging Tooth Bucket Excavator Attachment (A55973)
2021 Fleco DX140...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
2016 John Deere Gator (A55973)
2016 John Deere...
2013 POLAR TANK TRAILER CRUDE TRAILER (A58214)
2013 POLAR TANK...
17201 (A55852)
17201 (A55852)
2020 FREIGHTLINER M2 SERVICE TRUCK (A58214)
2020 FREIGHTLINER...
