How much Tractor do you need ? VIDEO #2
/ How much Tractor do you need ? VIDEO #2 #1
MutzFarm
Gold Member
Texas
Kubota M62
Decided to make another one of these videos with this here 4wd Mahindra 4025. Been a good tractor.
/ How much Tractor do you need ? VIDEO #2 #2
I have to ask - what is the goal of the discing? Are you breaking up the sod to farm it or just to smooth it out some?
In this particular application to smooth out dozer ruts. Why do you ask?
Also this is a coastal grass field that the cattle graze. It seems like when I make that coastal mad it just comes back beautiful. We will be fertilizing in about a month.
/ How much Tractor do you need ? VIDEO #2 #5
It seemed like you were doing a lot of cutting for just smoothing it out, i.e. too much tearing out of the grass. But then you have different grasses than what I am used to. We used to angle the disc dramatically but just run it over the top so it only really cut the high spots for levelling purposes.
I will say I hope I didnt kill the grass. On the fence because this should of been done already. Every so often I did leave about a foot untouched just in case. As mentioned above we will be fertilizing soon. Hopefully I didnt kill it and if so that bit I left will spread with the help of the fertilizer. Before the dozer it was almost like light brush country or light forest. Dozer ruts was my fault. I had dozer for X amount of time and it rained. I just figured I disc them smooth later.
/ How much Tractor do you need ? VIDEO #2 #7
How much tractor do you need? Just a little bit bigger than what you think you need.
/ How much Tractor do you need ? VIDEO #2 #8
I like that idea about the barrel with water. I have a disc and it needs some weight. No real spot to put it, but given your barrel idea, I might look for a couple spots.
/ How much Tractor do you need ? VIDEO #2 #9
If its an established pasture, you didn't kill the grass. Those roots should be going deep and should come back just fine. Especially with some fertilizer in a month.
/ How much Tractor do you need ? VIDEO #2 #10
That grass will be just fine
