Gravett1
I recently got a cub cadet mower from a friend, it's a cub cadet ltx 1045. It was sitting for about a year or more before I got it. I bought a new battery for it, fuel filter, spark plug, just the regular stuff for something that has been sitting to get it going again.
He said the reason it was parked was because it wouldn't start, it would just "click" so I bought a new solenoid, it started up for just a second then would die, it did that about 3-4 times. Then it appeared to be flooded, (smelled gas & seen gas coming out of the carb). So I let it set for a couple hours but still the same, just turning over but won't start.
I pulled the spark plug back out to clean it if/since it was flooded then put it back in, still the same. So I started testing the usual thing like is it getting spark. It's sparking and I believe it's getting gas to the spark plug since it appeared wet when I looked at it.
The point/question of this whole thing is, what do you think is the problem, since it's getting gas to the spark plug, and its firing?
I think maybe something got stuck in the carb or something after the first couple cranks, or maybe one of the safety switches went out, but I just don't know.
The gas tank was completely empty when I got the mower so if something got lodged somewhere along the gas flow it would have to be in the gas line or the carb I'd think.
Anyway please reply asap and thanks...dylan
