Food coloring for a dye?
   / Food coloring for a dye? #1
gwstang
Lake Martin Alabama
1952 Ford 8N / Kubota L2501
This sight glass for the hydro is about the stupidest thing ever. Very hard to tell if it's full or empty. Is there a reason not to just use some food dye to make it easier to see? I've seen the JD type dye on ebay but that is a ridiculous price for something like that. Maybe it's "magic" or something? :laughing:
My last motorcycle was a Yamaha VSTAR 1100 and for a pricey bike, it had a sight glass for the oil level. You had to lean way over, or on your knees, and then lift (Push) the bike off the kickstand. Then try to balance the thing in some semblance of level, while leaning way over to see the glass and if it is in the middle of the glass and pray not to let it get over too far and fall on the other side. Stupid idea but....at least we don't have to tip the tractor over to level and see the glass under the left floorboard. :laughing:
Sadly, I cannot ride anymore with a titanium plate in my neck, it just caused all kind of hurt. So I let it go. Swmbo was happy....but I was not. Heck, I put well over 150K on 5 different bikes, added together, and never had a wreck. Lots of close misses with deer and little old ladies that like to turn in front of big bad biker dudes...lol Yeah, right she (Wife) says. :laughing:
Food dye or not?
Re: Food coloring for a die?
Arrgh. It won't let me change the word "die" to "dye" in the title. Autocorrect sucks.
   / Food coloring for a dye? #5
John Deere Oil Dye part # John Deere Oil MT3668
David
That's what i used to combat the crystal clear SUDT2 & inconvenient sight glass in my old L3200. Used half the bottle & it worked great. Went to dump the last half of the bottle in my new L4060 because I had it around & it was dried out. The L4060 has a dipstick so its not hard enough to check to bother ordering a new bottle. Could barely see the level in the L3200 when it was in the sight glass, much less figure out if you were above or below the glass. At least until i dumped the dye in.
I wouldn't put water based dye in, doubt it would work & I try pretty hard to keep water out of my oil.
   / Food coloring for a dye? #6
I used the JD dye in my hydro Kubota!Worked great,almost impossible to see on the dip stick without it.
Note;when I brought it in for service the Kubota tech had thought I had put automatic transmission fluid in my hydro.Used two bottles,one may have been enough.Around $5.00 ea.
   / Food coloring for a dye? #7
Back in another century when I raced midgets and sprint cars, we burned methanol which is clear. There were no fuel restrictions back then so every week we would put a different color food die in the fuel so that the competitors would wonder what was in the translucent jugs. It really messed with their minds and may have cost some of them an engine as they added "combustion enhansers" to their fuel. :D. :D. :D
   / Food coloring for a dye? #8
:thumbsup: Bwwaaa-ha-ha-ha! (evil laugh).
   / Food coloring for a dye? #9
As long as the sight glass was actually glass, I won't be concerned with adding a dye. But if this is plastic of sorts, then I would stay away from dyes. The dye could permanently stain the plastic and make it even more difficult to read. Now, if you only have a dipstick then the dye would be great for that.
That is much more reasonable than the prices I've seen before.
"Food Dye is Water base... You need Oil base dye... KennyV "
I hadn't thought about that, thanks.
   / Food coloring for a dye? #12
I'm betting the sight glass in my old L3200 was plastic. But it never had any staining issues from the JD dye.
   / Food coloring for a dye? #13
I could not read the transmission dipstick level on my Kubota so I added a small amount of used engine oil, which darkened it enough to see easy. I service the transmission at the recommended hours, so I can not see any harm from the oil.
   / Food coloring for a dye? #14
Set the dipstick on paper & it will stain the paper where there is oil. You have to wipe the dipstick off then dip it again to get a good reading. Works good for me for now to avoid buying another bottle of dye.
   / Food coloring for a dye? #15
Never thought of that, will try it.
   / Food coloring for a dye? #16
We really need to lean on Kubota and have them come up with an Orange colored dye, putting Green in a Kubota is just wrong.
David
   / Food coloring for a dye? #17
David
The JD dye is actually red.
   / Food coloring for a dye? #18
I took a propane torch and heated the end of the dipstick until it turned blue. Just did it in the area where the where the oil shows and most of the dipstick didn't even get warm.
Now it's easy to see the clear oil against the darker dipstick. No scale, no additives, no problems.
luck,
rScotty
   / Food coloring for a dye? #19
Two words: Squid Ink.
Do NOT use the whole Squid-don't ask me how I know!
BN
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
2005 BOBCAT T300 SKID STEER (A60429)
2005 BOBCAT T300...
2008 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2008 Godwin...
2013 KOMATSU HM400-3 OFF ROAD DUMP TRUCK (A60429)
2013 KOMATSU...
2022 Chevrolet 1500 Silverado Crew Cab 4X4 Pick-Up Truck (A59230)
2022 Chevrolet...
2008 MAXX-D FUEL TRAILER (A58214)
2008 MAXX-D FUEL...
