Buying Advice In the market for a new tractor
   / In the market for a new tractor #1
Bluesman
selma nc
None
Hello all. New to the forum and could use a little advice. We have a small quarter horse farm and also raise Australian Shepard. Sitting on about 11 acres. The time has come to purchase a tractor. We have pretty much all the major brands nearby. That said we are really leaning towards the Massey Ferguson 1700 e series. They seem to have everything we need and nothing we don't. The tractor would need to handle round bales of hay once or twice a month. Also bush hogging pasture and maintaining 1/4 mile long private road. Any advice or suggestions would be greatly appreciated. Thanks.
   / In the market for a new tractor #2
You won't be disappointed, MF builds great sturdy tractors.
I would look at something in 35hp range tractor...can do just about any jobs on a small farm with this range.
Small enough for tight fits in the woods and yet big enough and plenty of power for pulling,tilling, mowing, FEL work.
Really like the 1734e. I think it would be all we need.
   / In the market for a new tractor #4
You can move round bales using a small tractor with Bale Forks mounted on the Three Point Hitch, but not lift the round bales more than 18". The MF 1734e has a Three Point Hitch lift capacity of 1,600 pounds, INCLUDING THE BALE FORKS. Round bales may exceed 1,600 pounds when damp.
You can lift, stack and load trailers with a 3,500 pound bare tractor with SSQA (Skid Steer Quick Atttach) Bale Forks mounted on the Front End Loader and counterbalance mounted on the Three Point Hitch.
What does HANDLE round bales mean to you?
TractorData.com Massey Ferguson 1734E tractor information
   / In the market for a new tractor #5
1200lb lift on the FEL should be able to handle the round bales fine with proper ballast. In my hunt JD, Mahindra, Case and NH (no massy around here) were the only ones with heavy enough lift capacities on the FEL for a round bale, they range in weight of 750-1500lbs so be sure to ask whoever you buy them from a ball park what they weight.
On bush hogging you need around 5hp per foot of mower, you can get away with less but you will have to drive really slowly. I see most people like to use 6ft bush hogs.
Also no matter what tractor you get, remember to keep bales low during transport and keep 4x4 engaged on any slopes or your only gonna have a light rear end to slow you down.
As far as the road maintenance, a garden tractor with a 3pt can maintain a driveway lol, unless your doing ground engaging any compact with a land plane will do you just fine.
(There is a guy on here that has a 4 wheel steer 700 series JD with a 5ft land plane he uses for existing gravel road maintenance)
The round bales we get are 800 to 900 pounds. Never wet...not too good for horses.
Just get them off the truck or trailer and into hay shelter. We peel off and feed from there.
   / In the market for a new tractor #9
I think you may find a 35hp tractor to be a little too small for handling round bales, depending on how high they are stacked on a truck or trailer. How high would the bale spear need to go to spear the bales, raise them up and lift them off the truck or trailer?
Please understand that the lift ratings for most tractor front-end loaders is measured at the loader pins. If you have a 5x5 or 5x6 round bale on a bale spear, a lot of the weight is 3-5 feet forward of the pins.
Plus, as someone else mentioned, the bale spear's weight eats up some of your lift capacity.
The golden rule for tractor buying is to figure out what size you need, and then buy one size bigger. It costs a LOT less to upgrade to the next bigger size the first time, than it does to buy too small and then lose your shirt trading up to a bigger tractor.
   / In the market for a new tractor #10
HP has nothing to do with lift capacity, very very little, it's all hydraulic pressure.
Here is two examples, 1. Ballast is very important with little compacts. 2. Proof a little tractor can lift a round bale, this one is 26hp, I remembered this video because my buddy bought a 2013 28XL last fall and was concerned about what it was capable of.
Mahindra 26XL lift test...lol - YouTube
With a proper ballast this little tractor could unload a single stacked trailer, it has the lift capability to double stack round bales, on paper it should.
The 26XL is rated at 1400lb lift capacity at 84 inches
http://mahindrausa.com/sites/default/files/tractor/pdf/23386 MAH54MAXT4 MAX Ser Bro 092016_0.pdf
I personally would step up to the 1500 series frame to handle a lot of round bales when weight is more your friend.
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
2021 Caterpillar 308CR Midi Excavator (A55973)
2021 Caterpillar...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2017 John Deere 6120E (A53317)
2017 John Deere...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
500BBL WHEELED...
