   / Share Pics of People Hauling or Towing Something Wrong #4,812
I think this guy will need another red fender to match the front one.
Two Men’s Attempt To Load A Trailer Goes Horribly Wrong
Lmao the driver acted like he had no idea how that could have happened.
I loaded my dump truck up on a trailer and that truck had no breaks, that was a stressful load and unload. Luckily nothing was hurt or damaged.
   / Share Pics of People Hauling or Towing Something Wrong #4,813
Lmao
We had "farm use" vehicles we drove around the farm,,, dirt/gravel roads only.
NO vehicle had brakes after 6 months to a year of use,,, luckily,
the 1,600 acres had no point more than 16 feet above sea level,,, it was flat.
Back then,, the cars and trucks were gear shift,,, time it right,, turn off the key - stop.
Some how,, it always worked,,, today social services would be ALL over the farm,,,
we started this at about 10 years old,,, there was too much work to do to worry about fixing brakes,,,
   / Share Pics of People Hauling or Towing Something Wrong #4,814
Just slightly redneck!
   / Share Pics of People Hauling or Towing Something Wrong #4,816
It's common for tractor dealers to pick up old trade-in tractors that have no brakes. Winching on is best, but even then you need to think about grade so the tractor does not try to leave the trailer in favor of the tailgate and pickup bed. Loading uphill slightly helps.
   / Share Pics of People Hauling or Towing Something Wrong #4,817
I could see that getting exciting!
   / Share Pics of People Hauling or Towing Something Wrong #4,818
Two other methods I have seen used are nailing blocks on the trailer where the tractor is supposed to stop or using a log chain to drag a weight or a vehicle with brakes to keep the winch in tension.
   / Share Pics of People Hauling or Towing Something Wrong #4,819
   / Share Pics of People Hauling or Towing Something Wrong #4,820
I've done that using some old tires as buffers
2012 PETERBILT 367 DAYCAB (INOPERABLE) (A58214)
2012 PETERBILT 367...
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
Yanmar YT359 (A53317)
2014 Freightliner 108SD Crane Truck, VIN # 1FVHG5CY3EHFL1495 (A57453)
2014 Freightliner...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56438)
2020 Westfield MKX...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
