This is BLASPHEMY, but here goes...
/ This is BLASPHEMY, but here goes... #1
knukey
Richmond, VA
Mahindra 2015 Gear/Loader
I own a 2004 Mahindra 2015 with loader. I use a ratchet rake on it along with a box blade (aka grader box) to rake my driveway once a year. I really don't use it for anything else. The blasphemy part, I'm thinking about selling it. I have a Suzuki Kingquad 750 and a snow plow.
Anyone ever put your ratchet rake on an ATV snow plow and use it to rake your gravel driveway? Will it work? Any other cost effective ways to use my resources and rake my driveway?
I hate owning a very expensive piece of equipment that only gets minimal use. I have asked for a quote from a local grader guy to rake the drive. I figure to pay a fee once a year for someone else to do it makes more sense than owning the equipment to do it myself.
/ This is BLASPHEMY, but here goes... #2
The part we are all having trouble understanding is that you have a tractor and unlike us you haven't figured out the 1001 other uses the tractor has besides maintaining your road. Sure I maintain my road, but I literally use the tractor for so many other things I would be hard pressed to name them all . It is a mystery to me at least that you don't do the same.
Baffled in Branson.. :confused3:
/ This is BLASPHEMY, but here goes... #3
I can see some small property owners who are not real motivated or creative not using their tractors, but mine hardly goes a week without doing something
/ This is BLASPHEMY, but here goes... #4
Me too. I could not live where I live and not have my tractor, pickup, UTV, and attachments. Wouldn't know what to do.
/ This is BLASPHEMY, but here goes... #5
At the risk of being shunned by my fellow TBN'ers (no, I'd not give up my tractor), I have noticed quite the array of attachments & implements for an ATV whilst wandering around the Ag Show.
The 'powered' pull-behind implements have Honda engine(s) or are geared to the wheel rotation. There was a combination disc/seeder/roller implement that was very innovative and was used with an ATV. Tractor 3PH implements are being downsized to be towed/operated by these vehicles, including side-by-sides.
There's a market out there.
/ This is BLASPHEMY, but here goes... #6
Yes there is. Then throw in the UTVs. I think I even saw a 3pt kit for the Kubota RTVs?
I'd say if the OP doesn't have a use for his tractor, he's better off selling it and using the ATV.
/ This is BLASPHEMY, but here goes... #8
I agree with my friend here from Branson. Have you considered seeking professional help ???
/ This is BLASPHEMY, but here goes... #9
This website is full of members that own a tractor they rarely use. If the OP is one of them, he should be applauded for realizing his error and recouping some of the money he's invested in this rarely used equipment. :)
/ This is BLASPHEMY, but here goes... #10
I can understand the OP's point of view totally. I have 12 acres, largely woods but several acres of open field, and a long steep gravel driveway. My tractor mows the field, vacuums leaves, plows snow, grades the drive, chips fallen limbs, and hauls firewood. But in between it can sit for weeks unused, maybe even a couple of months. I can't image thinking it would be fun to "be creative" and find some additional jobs for it. It's purpose is to get work done when it needs doing, nothing more.
I'm not about to get rid of it, because when I need it I need it. But I can see that if someone has other tools to do what needs to be done it might not be necessary. My Mule has taken over some of my small hauling needs, including taking me and hand tools down the driveway and back to do ditch maintenance, so my tractor gets less use than it did before.
/ This is BLASPHEMY, but here goes... #11
You could probably make a sledge/leveller landplane sort of implement that would tow well behind your quad. Just make the drag chains long enough it so it behaves itself. I have used a quad with a 12v spreader and towed a farm gate to sow grass in places too steep to take a tractor.. beats using an airplane..
I definitely hear what you're saying, pays to have your $$$ free if you aren't getting much out of your tractor then use that capital to get stuff for what you need. Farmers in Australia and NZ have heaps of stuff to turn a recreational machine into a serious workhorse. Mowers sprayers blades balefeeders etc. If you already have a snow blade then give it a blast... you may need something like leaf harrows to loosen it up. I chain harrow behind my cattle with a canam commander, less ground pressure than my tractor and an extra cup holder.. your 750 will have plenty of tow.
/ This is BLASPHEMY, but here goes... #12
Sell the tractor unless you can't come up with more uses for it. I know others will pass out that someone else said it but I can't see any justification for having it for a once a year project. I've seen a DR road grader for behind an ATV that might be just what you need. For me I used an old ATC (3 wheeler) to pull a section of I-beam behind it to grade the driveway with good results. It was long enough so I could pull it at an angle so it would knock down any washboards. It wasn't that useful for potholes but I'm sure I could of found a way to deal with them as well.
/ This is BLASPHEMY, but here goes... #13
The same crowd that recommends not owing a backhoe and renting one instead. :confused:
/ This is BLASPHEMY, but here goes... #14
I agree with your philosophy 100%. My tractor is a tool. Tools are for getting work done, not for simple pleasure. My tractor isn't for just joy riding around the property. But - when I need it, I need it. And I want it to be ready to go to work when I turn the key, thus it is maintained properly, as are all of my tools including the 4-wheeler, saws, etc. That's the pleasure that I get from my tools - being ready to go to work when needed.
On my weaker side, I have difficulty in getting rid of tools, i.e. trucks, tractors, hammers, saws, etc. that I haven't used in years. I suppose that's the hoarder side of me. I justify that part of my personality in declaring that one never knows when they might need a particular tool. So, I won't be selling my tractor...EVER.
/ This is BLASPHEMY, but here goes... #15
Knukey. Your idea sounds sensible to me, but I bow to the to the more experienced and wise ones here. I want to say what a nice garden you have, and ask what is the name of the flowering small tree/bush in the immediate background.
Thank you
John
/ This is BLASPHEMY, but here goes... #16
I have lots of work that needs done, but so little time to do it; especially if I didn't have my tractor. It is both a time-saver as well as a body-saver. While it may seem foolish, I also make myself available to any neighbors who need something done that they can't do easily without tractor capability. If I used it once a year, I'd get rid of it and rent one when I needed it - maybe. I'd rather have my ability in my yard full time than at the rental company on Saturdays.
Thanks for all the input. I doubted the ratchet rake on the snow plow had been done before. I will forge ahead bravely with this experiment. I'm concerned the springs on the plow will let the rake sag and it won't work.
I've had the tractor for 4 years. When I saw the ad on CL I didn't even know it had a loader (BONUS) so I could have done without it. Like everyone I have tried to find uses for the loader. I put the ratchet rake on it and that helped a lot. Still I don't ride around the yard looking for stuff to do with it. The tractor has been relegated to mowing (5' finish mower - which is a clumsy beast to use on my 4 ac. yard), snow plowing and once a year raking/grading. I've debated taking the loader off, but I fear it would become a yard ornament.
The loader, to me, is simply in the way (I can hear the gasps!).
Since I bought the Kingquad and it came with the snow plow, the tractor lost that job. I bought a Woods 5215 60" mower (fine tool for quick efficient mowing) more because I like it than need it - another job lost for the tractor. Now I'm down to raking only.
I'm not hurting for money or anything, but I could invest the sale proceeds and invest for the kids college or my retirement.
/ This is BLASPHEMY, but here goes... #18
If you can't find a use for a FEL, then I agree, get rid of the tractor. Me, I cannot imagine life without a FEL. Seriously.
/ This is BLASPHEMY, but here goes... #19
2 years ago I bought a zero-turn to cut my 6 ac yard after cutting it with my tractor for 8 years. The zt cuts it a little quicker, a lot less damage to the yard, cut my weedeating time a lot but I still need the FEL on the tractor to stand the 60" heavy deck up to clean/service it !!!
I can't imagine life without my tractor, I use it for a lot of stuff around here and it makes me a little money when I do some work for neighbors. That 6' FEL bucket is the very best wheelbarrow I've ever owned ! It's rare for my tractor to sit more than 2 or 3 weeks unused, year 'round. I can understand though that if I couldn't think of anything to do with it for a year at a time I might get rid of it.
/ This is BLASPHEMY, but here goes... #20
I don't see why this would not work as long as you can get it to attach. Though I don't think I would try to use it other than for back dragging.
Post your results!
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
Hydraulic Mini Excavator Attachment (A61572)
Hydraulic Mini...
2019 CATERPILLAR M316F MOBILE EXCAVATOR (A63276)
2019 CATERPILLAR...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
2012 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2012 Chevrolet...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
