Best used attachment under $500.
/ Best used attachment under $500. #1
rdinatal
Gold Member
Lake Normanopolis, NC
Old: 2016 eMax25s HST, New: 2017 Max 26xl HST
The title should say "Most Used Attachment"
What if you had $500 and wanted to spend it on something. For arguments sake you had a (S)CUT, FEL and a rear blade (box or scrape).
What would you get and why?
-R
/ Best used attachment under $500. #2
In my case, at $500 it would be my 9' Flail mower, which I have yet to see in person. But will Friday night. Hope to try it out on Saturday. Otherwise I guess a 5' Rotary mower would be useful.
/ Best used attachment under $500. #3
What type of property and how much property do you have.
What do you do on property
Generally rotary cutter
/ Best used attachment under $500. #4
If you don't already have a drawbar they can be handy. Cost almost nothing and great for dragging and pulling posts/etc out of the ground.
/ Best used attachment under $500. #5
If I did not already have one,,, I would buy a $200 chain,,,
for that much, it is unbreakable,,, and doubles as a front end weight!! :thumbsup:
/ Best used attachment under $500. #6
Landscape Rake
Bolt on Grapple
Disk
Toothbar
Omni Hitch
Middle Buster (Sub-soiler)
Clamp on Forks
Ken's Bolt on Hooks
/ Best used attachment under $500. #7
Something to work the soil. Ripper, plow, cultivator. Ken Sweet
/ Best used attachment under $500. #8
I paid $100 for my ancient 7' Ford 917 flail. Have about $500 into it now with parts. I'd agree it's my most important implement. Good luck in finding one... there have been 7 posted to Craigslist in Colorado in the past 2 years, most crop flails or overpriced. A rough cut rotary cutter would be the much more likely alternate.
My box blade is #2 on my list. I've done a fair bit of digging & grading with it as well as the expected driveway maintenance. A land plane is on my build or used bargain hunt list. They are easier to use & level/smooth better than a box, but not as flexible.
/ Best used attachment under $500. #9
Really does depend on your land. I would be lost without my landscape rake. A boom pole is also in my sights.
/ Best used attachment under $500. #10
My "most used" for the compact tractor would be 3PT hitch hayforks. Fencing, cutting trees and brush, moving things.
/ Best used attachment under $500. #11
These questions will need to be answered before anyone can give a good answer. In my case as with others a used flail mower was the ticket for mowing my 8 acres and as of last summer the most used implement I have.
That may change as late in the season I bought a 60 inch zero turn and am planning on mowing as much as I can with it. The problem is I have mowed allot of the property with the tractor when it was really too wet and have created tire ruts all over the place. This makes mowing with the ZT a pretty bouncy proposition. Could very well be next summer a plow and tiller will be the most used implements as I plow then till most of the property to level it out.
Less than 5 acres but the real use is as a landscaping tool. I'm saving up for a backhoe but I just might have to stretch for it sooner than later. No grass cutting for me, done enough of that when I was 15!!!!
What I have now:
Rear scrape blade
Subsoiler
Draw bar
Tow hitch w/2"x2" receiver (trailer mover)
Bucket hooks and D-Ring
Filled tires
Lights on ROPS
I was thinking of a set of Edge Tamers but there are some good ideas here.
-R
/ Best used attachment under $500. #13
Tow hitch,hooks on bucket and a chain. Should have $$ left.
/ Best used attachment under $500. #14
Then Landscape rake, many uses.. I use mine mostly for our gravel drive.
/ Best used attachment under $500. #15
Ratchet Rake. Already cleared 1.4 acre in about 50 hours
/ Best used attachment under $500. #16
Surprised no one has suggested pallet forks. Use them as much as anything and less than 500 bucks. Trailer mover is a well spent 100 dollars.
/ Best used attachment under $500. #17
Just getting ready to mention forks and you beat me to it...
/ Best used attachment under $500. #18
I have about 500 in my grapple, use it all the time, next up would be my pallet forks.
For the rear I use my tilt and offset scraper, unless my backhoe is attached.
/ Best used attachment under $500. #19
I have a lot of grass and cover crop in and around my vineyard. For $500, I would get a used 3pt sprayer, and would probably have enough left over to get a small spot sprayer for the quad.
Can't imagine fighting weeds with a hoe.
Komatsu D65EX Dozer (A66285)
Komatsu D65EX...
2022 RBR Venturi 430 High-Capacity Pneumatic Applicator (A63688)
2022 RBR Venturi...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65563)
IMPORTANT PLEASE...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
2015 MGS GODWIN CD150M PORTABLE DRI-PRIME (A63276)
2015 MGS GODWIN...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
