Branson 2910
/ Branson 2910 #1
Dlepierre
Floral city
Branson
I recently bought a used 2910. It's giving me a little trouble and cannot seem to find a repair or service manual. Anyone know where I might find one. Every thing I have found on the Internet seems to be spam of some sort..
/ Branson 2910
Thankyou very much Has anyone replaced a clutch on one of these before looks like I'm about to.
/ Branson 2910 #5
I have replaced dual stage clutches before (not on a Branson though), and it is tricky but not impossible. It definitely requires a clutch alignment tool specific to your tractor, and a lot of patience to get everything to slide back together (that is really the only hard part). It helps to get some extra long bell housing bolts to align the front half with the real half of the tractor, then put the stock ones back in once it slips together.
/ Branson 2910
That's a great idea I will check fasten all for those long bolts. I tried the links for a service manual but they only had the new models. Anyone have a pdf. I think the 3510 is the same.
/ Branson 2910 #7
Expect to pay about $18 for each bolt!!
I found some long bolts with the same thread (14mm) as my front wheels (so I can add weights) on ebay pretty cheap
/ Branson 2910 #8
A manual would be nice, but you can probably live without it. I'd take LOTS of pictures as you tear everything down. Take a picture of everything you take apart on the tractor, especially the clutch. It is amazing how much that helps when you go to put it back together. You will no doubt find that you tore it apart more than you needed to when all is said and done.
A two stage clutch as two sets of spines on the transmission input shaft that has to align with their individual clutch. Lightly lube the tranny splines. One trick is to rotate your input tranny shafts so that they are in the same relationship as the splines on the alignment tool. When that doesn't work :), you will have to rotate the engine, PTO shaft (if it is a direct drive) and/or rear wheels to get them all aligned. Usually the forward clutch splines engage before the rear, so it isn't as hard as it sounds. Don't force it together with the bell housing bolts! I have used cheap Harbor Freight wood clamps to pull the two halves of the tractor together the last inch or two., just using minimal force. Sometimes it doesn't even take that. Just make sure the front half of the tractor is on the same center line as the rear, rock things back and forth, and turn the shafts, and it will slip together.
A cherry picker (Again a cheap one from Harbor Freight will work) works well to hold up the front half of the tractor during this whole procedure.
/ Branson 2910 #9
Oh, one other thing I did once that made all the difference: I filed the leading edge of the splines on the tranny input shaft down to a 45 degree angle so they would slip into the clutch without perfect alignment. It doesn't take much, just a bit. Yours may already be made that way.
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A60352)
2015 GMC 3500 HD...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
