Lowering attachments to the ground
/ Lowering attachments to the ground #1
mcfarmall
Kalamazoo, MI
Kubota M5660, Farmall C, JD 260 lawn tractor
Does anybody but me lower their attachments, loader, etc. to the ground when parking their tractor or other ag equipment? I've seen more combines and tractors parked around in fields and farmsteads with the headers up in the air, loader buckets and bale spears in the air, brush cutters, plows, blades, etc. all flying high.
I was taught that when you park a piece of equipment, you lower ALL implements and attachments to the ground for safety.
/ Lowering attachments to the ground #2
They probably want to keep passersby or nosey kids from getting to the equipment.
/ Lowering attachments to the ground #3
I always lower all attachments to the ground.
/ Lowering attachments to the ground #5
Same here. But it makes me wonder why the other owners leave them up??? ,,,beside nosey kids ... which seems remote to me in a farming neighborhood......maybe rust??
/ Lowering attachments to the ground #7
I lower mine. I've always see combines with headers up - must be rust. Otherwise, most ground engagement implements are pulled via the drawbar and are down.
/ Lowering attachments to the ground #8
Always lower mine, unless, there is a chance the tractor will not start when I use it next time. Ken Sweet
/ Lowering attachments to the ground #10
All equipment training courses start out with safety procedures. Lowering attachments or implements is a #1 safety item and is covered by OSHA as such Big reasons are they create a tripping hazard, are prone to being run into by the unaware, and Sudden release of hydraulics or brakes can drop the item. I have seen contractors lift their generators and etc up on the crane hook and leave, (apparently to thwart theft). Safety wise that is a No! No!. Fines are levied on that procedure often.
Ron
Yeah, I've seen wads of equipment and tools hung high up on a crane hook. My favorite is the oxy-acetylene torch cart.
I lower stuff to the ground and tilt the bucket or forks down so the cutting edge and tips touch the ground for foot/leg/ankle safety.
/ Lowering attachments to the ground #12
Was told by my Pa that if a cylinder is all the way extended there is no room for thermal expansion and plays havoc on the seals. Dunno who told him or if true but my stuff is always on the ground with levers jiggled after engine is off.
I drive by a Farmall M with a F11 that sits for months with the loader as high as it can go. I never could understand why. Not in a confined space either.
/ Lowering attachments to the ground #13
Same here. Basic equipment safety goes a long way towards keeping all of your fingers and toes intact.
/ Lowering attachments to the ground #14
Went to the county fair last summer. Many equipment dealers there and kids CONSTANTLY climbing on the tractors, pretending to drive and moving levers. The dealers are very "patient", it's been this way for decades. For some kids climbing on the tractors is probably better than the rides. Adjacent to the equipment is the horse arena, and just outside that is where the volunteer parks the tractor and with a chisel plow that they use to maintain the arena.
Yep, you guessed it. The #&%$ leaves the chisel plow 3 feet in the air. Just waiting for a kid to come along. I walked over to it and slammed it to the ground hoping to make the biggest ruckus I could. I looked around to see who I could give a dirty look to, but alias, no one was monitoring the situation.
I wouldn't think that typical thermal expansion pressures in a cylinder would exceed the operating pressure which in many cases could be 2,000 psi. Pa's theory would be the same if the cylinder was all the way retracted too. Maybe he meant that a cylinder should be stored somewhere mid stroke to avoid issues but I still contend that hydraulic pressure due to normal atmospheric temperature changes would not exceed the operating pressure rating of the cylinder.
At any rate, it's cheaper to fix a leaky seal than a crushed or impaled body part.
/ Lowering attachments to the ground #16
I'm pretty good about lowering everything to the ground when I park the tractor. However, sometimes I forget to raise everything back up before I drive off next time I use the tractor.
/ Lowering attachments to the ground #17
Haha I thought I was the only one. Box blade is noisey!
/ Lowering attachments to the ground #18
As a kid, I just loved construction sites after hours. Big bonus when stuff was left raised. I'd lower it a little at a time to stretch out the experience. I guess, it's when I got hooked on hydraulic equipment.
Leaving stuff raised can tell you if you have a leaky,worn or poor quality system. Unless of course some kid has been around.
/ Lowering attachments to the ground #19
Same. I went out to finish plowing the other day, pulled out with the ballast box sitting on the snow. It did not make enough noise for me to hear it, I must have gone 20 ft before I looked back, a VERY FLAT stripe the ground. Ooops.
/ Lowering attachments to the ground #20
The big problem is when unsupervised kids are around. One or more kids can be climbing over, under, or around a raised implement while another is on the seat or in the cab playing with the controls. That can end in a disaster for someone's family and a nightmare for equipment owner faced with a lawsuit.
2022 TEXAS PRIDE DUMP TRAILER (A65643)
2022 TEXAS PRIDE...
2013 Ford Focus Sedan (A61574)
2013 Ford Focus...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
2018 Mahindra Mpact XTV1000S (A64127)
2018 Mahindra...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
John Deere 8R 310 (A64126)
John Deere 8R 310...
