Fired Road contractor. Build it myself?
   / Fired Road contractor. Build it myself? #211
Following this thread with much interest. You guys have it sussed. After having a chat with Egon, and a few days thought, I'm on the lookout for a broken plow/plough as I want to use the steering system as well, on my build. So it will always be centred to the headstock, even with it offset to the side- will be both heavy duty and half built already. Plus I will utilise the plough beam to mount the wheel from the headstock, not the blade's beam.
Just a thought.
(Only have a 6' blade on 8'6" wide tractor)
Surely there's some lying around.
   / Fired Road contractor. Build it myself? #212
Or you can go nuts with wheels :D :D
That is a beauty!
Seem's there are many folks out there with gauge wheels and showing their setups. Lots of nice setup's that make me envious. If I' go to the other computer I could show some pictures of why. Give me a little time.
   / Fired Road contractor. Build it myself? #213
OK, some pictures.
The first is my back blade with one gauge wheel showing. It's not in a working position. The second and third show a before and after grading for boat house pad and ramp going to lake. Tractor is a Kubota B7100 HST.
   / Fired Road contractor. Build it myself? #215
   / Fired Road contractor. Build it myself? #216
Another shot of it, a much bigger one behind it.
(sorry about the size of the last one, I went back and reduced it)
I like the spillage wing at the tip of the blade.
ALL rear blades need those,,, I hate when that material overflows off the end of the blade.
   / Fired Road contractor. Build it myself? #219
   / Fired Road contractor. Build it myself? #220
You accidentally got a rock stuck in your blade,,, did you notice it there?
I think you can get it out with a crowbar,,, :thumbsup:
:laughing:
The danged thing popped up and got stuck. Seemed to work better so I just left it there!
(4) GOODYEAR WRANGLER 275/55R20 TIRES (A54757)
(4) GOODYEAR...
2006 APPA TL (A55787)
10ft Pallet Fork Extensions (A54865)
10ft Pallet Fork...
2014 Mack CXU613 Truck, VIN # 1M1AW02Y6EM040637 (A54865)
2014 Mack CXU613...
2017 PETERBILT 579 DAYCAB (A55745)
2017 PETERBILT 579...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
