Blades on a box blade
Status
Not open for further replies.
/ Blades on a box blade #161
:mur: OK, you've talked us into it. Since it's been working for years, we're going to leave them alone & carry on business as usual. :banghead:
:cool2: Travis :cool2:
Why don't you call your blade manufacturer and ask them to replace their defective blades, when I look at these holes drilled in the cutter blade you can see they have been cut at different depths and the material remaining at the bottom is really thin. I think that would be a better way to go about it.
/ Blades on a box blade #163
We have never ever ever. I repeat, We have never ever ever never ever never ever ever had a cutting edge failure.
Travis
/ Blades on a box blade #164
Travis, that's been your intent since the beginning of this thread. And if you hadn't confessed it we still wouldn't know the brand of BB in question. We've had some good debate concerning three construction issues. None of which doom the product as non-functional. Each a deficiency. The top link holes should align. The moldboard should be straight. The cutter bolts should not protrude thru the cutter that far.
Not selling any more BBs unpainted and disassembled will overcome two of the three. Maybe no one will notice the top link holes.
/ Blades on a box blade #165
Travis, that's been your intent since the beginning of this thread. And if you hadn't confessed it we still wouldn't know the brand of BB in question. We've had some good debate concerning three construction issues. None of which doom the product as non-functional. Each a deficiency. The top link holes should align. The moldboard should be straight. The cutter bolts should not protrude thru the cutter that far. Not selling any more BBs unpainted and disassembled will overcome two of the three. Maybe no one will notice the top link holes.
What he said.
/ Blades on a box blade #166
QUOTE=Catman8;4680572]Why don't you call your blade manufacturer and ask them to replace their defective blades, when I look at these holes drilled in the cutter blade you can see they have been cut at different depths and the material remaining at the bottom is really thin. I think that would be a better way to go about it.[/QUOTE]
I'm the new guy here in the group. I'm shopping for implements and have called them probably 6 times now figuring out what i want.. always super nice..
I unfortunately read all 17 pages of this thread b/c I'm shopping for box blades. they said more than once they'd refund your $ even cover your cost of paint, right? so why keep pounding? sounds like they're trying to do the right thing if even they are now in defensive mode..maybe you don't like their answers but again, at least they gave you an out...
just my 2 cents...
i have zero affiliation with them but i'll give you another out....
I'm not fond of yellow and green but i'll take it for $200 it's a triple win..u got your $ back and buy another implement, they get it out of your hands, and i get to pull the little piggy up and down the side of the Va mts. moving dirt and rock as it was intended to do... I can pick it up from them when i pick up my Wicked grapple...
we got a deal?????
/ Blades on a box blade #167
The misaligned top link hole is inexcusable and I have pronounced it as such to mr. cat and here the public. Flash back to when I said we are not perfect, but we do make a d@mn good, well received product that is consistent a very high percentage of the time.
BUT, a painters eye could have caught it! :thumbsup:
Travis
/ Blades on a box blade #168
Travis
Yep, I believe you do in fact make a good product. Problem all thru this thread has been your inability to admit that this time you did not. And based on your last comment, is your painter your QC?
/ Blades on a box blade #169
Thanks ovrszd.
Man, If he had put that thing in the dirt and used it the amount of time we lost on this thread, he would've had the whole county leveled.
Nope, but he's an extra set of eyeballs.
Travis
/ Blades on a box blade #170
Thanks ovrszd. You are Welcome.
Man, If he had put that thing in the dirt and used it the amount of time we lost on this thread, he would've have the whole county leveled. And maybe hundreds of BBs have been built and shipped with these problems. If that's okay with you, it's certainly okay with me.
Nope, but he's an extra set of eyeballs. Can't have too many of those!!! :)
Travis
Thanks for your patience Travis. :)
/ Blades on a box blade #171
Mods, I think that every possible design and fab flaw that might happen, as well as dozens of possible resolutions for each, not to mention every frustration, has been covered ad-nauseum in this thread, yet the frustration seems to continue to climb. Maybe a good time to close the thread?
There should be no frustration, if we can not have intellectual intelligent conversation about fabrication issues and how to improve on those designs without one party getting mad and refusing to join in on the conversation and then leaving the thread multiple times, then maybe they should not be a forum sponsor. As an adult and business owner, or employee representing a company you need to conduct yourself in a professional manner! The OP of this thread has been respectful, courteous, civil, and has praised EA over and over throughout this thread about many good features of this box scraper with not even a thank you from EA. The only thing you should be nauseated about is a company calling a customer (left field crazy) for simply asking to work through a few minor issues, or asking a company questions about improvements they can make without the company getting mad.
/ Blades on a box blade #174
And this is why dealer/customer disputes should not be aired in public forums and why its usually not allowed on TBN.
He said, she said... private messages dumped to the public. Returned calls, not returned calls. Emails, no emails... and never a shortage of axes to grind. :rolleyes:
Status
2001 FORD SUPER DUTY F350 4x4 UTILITY TRUCK (A59912)
2001 FORD SUPER...
2008 Ford Mustang Convertible Coupe (A61574)
2008 Ford Mustang...
213089 (A64276)
213089 (A64276)
2018 LANDOLL 330 S/A  DROP DECK TRAILER (A59912)
2018 LANDOLL 330...
2006 Toyota Sierra CE Van (A61574)
2006 Toyota Sierra...
2007 International 8600 Parts Truck (A63689)
2007 International...
