MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 66,760
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
My in-laws gave us their log splitter. Its a tad over 30 years old, but still strong. They heated their house with wood for about 25 years and we've heated ours that way for the last 6 or so. It has a 5hp Briggs engine that still runs strong, but I have to add oil about every two tanks of gas and the plastic disc that holds the rope for the pull starter exploded, taking the metal shroud with it, and several of the fins on one side of the flywheel. I found replacement parts, but with shipping, they were north of $50. So, spend $50 on a 30 year old engine that uses oil, or replace with Harbor Freight Predator 6.5hp for $99.99? Off to Harbor Freight I went.
Got it out of the box and inspected. Looks nice. :laughing:
Removed the pump mount from the old engine (4 nuts).
Removed the old engine from the splitter 2 bolts (supposed to be 4, but 2 were missing!).
Compared the old and new engines... motor mount holes are exactly the same.
Compared the pump mount stud holes, exactly the same.
Compared the shaft, exactly the same diameter and length.
Set the new motor on the splitter, dropped in 4 new 1-1/2" 5/16th x 18 bolts, washers, lock washers and lock nuts.
Removed the shaft key for safe keeping.
Added 1/2 quart of 10w30.
Filled the gas tank.
Turned it on, turned on the fuel valve and choked it.
Started on the 2nd pull.
Ran for 3 hours at 1/2 throttle per the break-in instructions with no pump mounted.
Seemed to run fine. I varied the throttle several times over the course of the three hours.
The engine never really got hot. I could put my hand on the valve cover and it was just warm.
So, in the next few days I'll install the pump mount studs, the engine side of the lovejoy connector, mount the pump and give it a try.
