What do you consider to be high hours?
   / What do you consider to be high hours? #21
Anything past 10 PM and I often fall asleep. :D
Yeah, anything over 40 hours a week is high hours! Being paid overtime helps a little, though. ;)
A little more seriously, for your Kubotas, Mahindras and similar, my number is 4,000 would be too high for me to be comfortable buying used. I'm not a mechanic. But that wouldn't necessarily be because of the engine, but total package wear and tear.
   / What do you consider to be high hours? #22
... for your Kubotas, Mahindras and similar, my number is 4,000 would be too high for me to be comfortable buying used. I'm not a mechanic. But that wouldn't necessarily be because of the engine, but total package wear and tear.
Something in that category is a gamble, I've won some lost some, but on average over a lifetime I'm many dollars ahead compared to buying only new or in the 'dealer-certified used' category. The two tractors in my sig photo below were winning gambles, both are some 30 years old. 13 troublefree years now on the green one after a few hundred $ bringing neglected stuff back up to spec - a battery, ignition switch, etc. The red one dyno-tested better than spec after I bought it a few years ago. But of course I've also had some losers. An old Volvo that turned out to be the front and rear halves of two different cars welded together - and a 1980 Chev Citation I bought new that was worn out at 35 k miles and couldn't maintain freeway speed when I traded it in at 45k miles. (Both a slipping clutch and a flat camshaft, and needed a few thousand $ to fix other failed stuff like the A/C.) My point is if you don't earn your living with the tractor why not take a chance, set aside a reserve to get it up to spec, and spend the money you saved on something else more important.
   / What do you consider to be high hours? #23
Yeah, anything over 40 hours a week is high hours! Being paid overtime helps a little, though. ;) A little more seriously, for your Kubotas, Mahindras and similar, my number is 4,000 would be too high for me to be comfortable buying used. I'm not a mechanic. But that wouldn't necessarily be because of the engine, but total package wear and tear.
I'd be afraid of a 4,000 hour compact tractor. The engine probably still runs fine, but the rest of the machine is probably well past its prime. I would still buy one, but it would have to be really cheap.
   / What do you consider to be high hours? #24
Prior to this weekend, the highest tractor I ever saw was a 1960's Deere with 14,000 or so. This weekend I saw an 18,500 hour industrial tractor up for sale. Still looked pretty good. I consider 9,000 on a farm tractor high and 2,500-3,000 on a compact tractor high-ish.
   / What do you consider to be high hours? #25
We have forklifts at work that are 10 years old maybe and many of them have eight to twelve thousand hours on them. Toyota forklifts with Toyota engines but I think they're the same as some small car. They are running on propane, they get started at 6:30 or 7 in the morning then during Harvest they'll run till 6:30 or 7 at night. Otherwise they get shut off around 3:30 but they're either driving around or idling the whole time in between.
Aaron Z
   / What do you consider to be high hours? #26
It all depends on the maintenance and up keep (that include cosmetics). I have a JD 4960 with over 10K hrs on it, never rebuilt. Only because of a rod bolt replacement (recommended by a JD service bulletin) we replaced the rod bearings as well. Funny the old bearings looked fine, but we were there.
   / What do you consider to be high hours? #27
I'm leaning your way but it really depends on usage. Was it a mower, digger? idling or straining? And when I say straining, I mean metal strain.
   / What do you consider to be high hours? #28
We could make up any conditions for the topic of discussion. Since it's a second hand heavily used tractor it's likely done all off the above, and you don't know it's history.
   / What do you consider to be high hours? #29
Exactly. Just trying to toss in a few subjects to probe the seller.
'Heavily' is a relative term. I have found that asking a few open ended questions to get the seller talking is the best strategy. This breeds an honest discussion, truth, the beginning of a potential relationship, and your best bet of feeling good about your transaction. :2cents:
   / What do you consider to be high hours? #30
The imagery tractor in discussion has 4000 hours. That's pretty heavy use compared to the average TBN user.
2020 CATERPILLAR 299D3 XE SKID STEER (A52709)
2020 CATERPILLAR...
2008 CAT 305C (A53317)
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
CLUB CAR (A55758)
CLUB CAR (A55758)
