Oil & Fuel Rear End / Trans / Hydraulic oil on '54 NAA - continuous or separate??
  • Thread starter Deleted member 66551
  • Start date
   / Rear End / Trans / Hydraulic oil on '54 NAA - continuous or separate?? #11
I have to agree with rick.
My NAA owners manual dated sept 52 specifies A or C type hyd oil int he hyd ssytem.. not the gear oil it reccomends for the tranny or the diffy.
IE.. the hypoid gear lube is M-4642D or E
The hyd fluid is M-4864A or C
I see similar refs in my X00 and X01 manuals.
I don't doubt there may have been some kind of reginal talk / interoffice memo's between service managers.. whatever happened.. it didn't become global and go out in print in the owners and service manuals.... so.....
soundguy
   / Rear End / Trans / Hydraulic oil on '54 NAA - continuous or separate?? #12
soundguy
HELP !!!!!
Too much information here!
True or False ....?
TSC - "Traveller Premium Universal Tractor Trans/Hydraulic Fluid" is 100% satisfactory for EVERY use in my 1951 model 8N... EXCEPT THE ENGINE?
   / Rear End / Trans / Hydraulic oil on '54 NAA - continuous or separate?? #13
HELP !!!!!
True or False ....?
It is fine for the common sump that is the transmission, rear axle and hydraulic system of your 8N. Do not put UTF in the steering box, radiator, or oil bath air cleaner.
   / Rear End / Trans / Hydraulic oil on '54 NAA - continuous or separate?? #14
If I were in the Sahara desert, and there was no oasis in sight, and with spare pails of UTF, I might consider it for any of those uses.
The thread is about transmission/rear axle/hydraulic use. My use of EVERY was a poor word choice.
CATERPILLAR HM315C QUICK ATTACH HYD MULCHING HEAD (A54757)
CATERPILLAR HM315C...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
(2) GOLF BAGS W/ CLUBS (A54757)
(2) GOLF BAGS W/...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
