Front bucket mount HD25 Post Hole Digger......easy remove/install?
/ Front bucket mount HD25 Post Hole Digger......easy remove/install? #1
JOHNTHOMAS
Super Member
Somerset, Ky
F2690 4WD RTV X1140 MX5400 HST ZD1211
Picked up my B2650 yesterday at Barlows with my new HD25 Landpride posthole digger and 12" auger installed. Have to keep the bucket high to move around! I augered it into the ground and had other things I had to do so not much time with it and it's wet, wet, wet here.
The concern....It mounts to bucket with 4 bolts and then the first pivoting connection has a cotter pin bent on the ends. The next connection also has a bent cotter pin holding it on. The plate with the 4 bolts attaching to the bucket seems like it could stay on while using the bucket but the rest of it has to come off or will be packed with dirt/gravel/? that the bucket is working. The first pin appears to be the place to remove the PHD while not using it but owners manual says to install pin and bend the ends?
Anyone own a front bucket side installed hydraulic post hole digger? If so, How do you easy remove/install it? I will remove the 4 bolts or unbend the cotter pin to do it but wondering about other peoples actual experience doing theirs. I'm considering mounting the 4 bolted plate to the front of my SSQA adapter plate and use the PHD straight off the front instead of off the side of my bucket which is the manuals recommended way to use it on a skid steer. I already have a plate which I have my snow plow hooked to but plan to use snow plow on RTV1140 which doesn't use the adapter plate for connection.
OK, you that have one and used it tell me your method.:anyone:
/ Front bucket mount HD25 Post Hole Digger......easy remove/install? #2
You could replace the cotter pins with hair clips.
I was going to suggest mounting it to a SSQA plate also.
/ Front bucket mount HD25 Post Hole Digger......easy remove/install? #3
I use this SSQA plate which allows easy front mounting of a post hole digger and many other 3 pt hitch attachments. It also has a 2" receiver hitch which is useful to maneuver trailers around the property:
Amazon.com: Skidsteer 3 Point Attachment Adapter Skid Steer trailer hitch front loader case: Home Improvement
Sorry, I can't help with your side mount issue.
I have this SSQA adapter and it's now connected to my snow plow for easy tractor hook up but plan to remove it and use the snow plow on my RTV1140.
Do you have a hydraulic PHD attached to this SSQA adapter plate and if so do you have pictures you'll post?
/ Front bucket mount HD25 Post Hole Digger......easy remove/install? #5
I used to borrow my neighbors hyd. PHD but he sold it last year. Since I don't need it much, I rent one from my dealer when necessary.
2018 Kubota L2501 (A60462)
2018 Kubota L2501...
2019 FORD F-250 XL EXT CAB TRUCK (A59823)
2019 FORD F-250 XL...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2015 Ford F-350 4x4 Ext. Cab Service Truck (A61568)
2015 Ford F-350...
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
