Does anyone know how to calculate the volume of this figure?
   / Does anyone know how to calculate the volume of this figure? #1
4570Man
Super Star Member
Crossville, TN
Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
This started out as trying to come up with a semi accurate amount of fill needed to fill a retaining wall. I've been unable to figure it out and it's turned into a personal mission. The shape has a rectangular base with one side being 4 feet high with the adjacent corner being 0 feet high. The other adjacent corners are 1 feet high. The rectangle is 22 feet by 55 feet. The only number I've came up with is 67 cubic yards. Here's a paper model I built. IMG_9031.JPG Here's a drawing of the dimensions if it helps. IMG_9032.JPG
   / Does anyone know how to calculate the volume of this figure? #2
I didn't know there was going to be a quiz....
   / Does anyone know how to calculate the volume of this figure? #3
It looks like 4 triangles that will need to be calculated separately. Then the rectangular areas are LxHxW. Remember to use all the same units of measure. It's easy to say 6 inches by 27 feet etc when it should be 0.5 feet by 27 feet. That will give you the cubic feet. Their are 27 cubic feet in a yard which is how concrete is ordered.
   / Does anyone know how to calculate the volume of this figure? #5
Did it two completely different ways and came up with 64.17 cubic yards both times.
For the simple approach -- take an average of all four heights, which works out to 1.5 feet. Then do 1.5 x 21 x 55 / 27.
   / Does anyone know how to calculate the volume of this figure? #6
Here's my guess.....
Cut it up into rectangles and triangles.
From top down, its basically a 22 x 55 X 3' rectangle sliced in half on a tilted diagonal sitting on top of a 22 x 55 x 1' rectangle, with one quarter missing.
So
22 x 55 x 3 = 3630 * .5 = 1815
plus
22 x 55 x 1 = 1210 x .75 = 907.5
EDIT: OOPs,
Forgot to cut my top rectangle in half... :mur:
1815 + 907.5 = 2722.5 / 27 cubic feet per yard = 100.83 yards.
   / Does anyone know how to calculate the volume of this figure? #7
Have them truck in fill until you can say "One more should do it."
Bruce
Did it two completely different ways and came up with 64.17 cubic yards both times. For the simple approach -- take an average of all four heights, which works out to 1.5 feet. Then do 1.5 x 21 x 55 / 27.
That's how I did it before and came up with 67 yards.
   / Does anyone know how to calculate the volume of this figure? #9
So
plus
EDIT: OOPs,
Drew it up in sketchup and I guess its not half of the top rectangle, its a quarter....
So... one more time...
22 x 55 x 3 x .25 = 907.5
plus
22 x 55 x 1 x .75 = 907.5
907.5 + 907.5 / 27 = 67.222
Boy, pictures sure help! :laughing:
Drew it up in sketchup and I guess its not half of the top rectangle, its a quarter.... So... one more time... 22 x 55 x 3 x .25 = 907.5 plus 22 x 55 x 1 x .75 = 907.5 907.5 + 907.5 / 27 = 67.222 Boy, pictures sure help! :laughing:
We got there different ways, but that's the same answer I got. Now how many yards of dirt are on a tri axel truck? Concrete isn't in the budget. We'll fill most of it with dirt and then gravel.
New Holland H7230 Discbine (A50775)
New Holland H7230...
2000 SCHWING P88 PORTABLE CONCRETE MIXER (A51247)
2000 SCHWING P88...
2000 Mercedes-Benz S-Class Sedan (A53424)
2000 Mercedes-Benz...
TRASH TRAILER 16 T/A (A52472)
TRASH TRAILER 16...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A53421)
2025 Single...
