Zerk fittings
/ Zerk fittings #1
alafarm
Moulton, al
Belarus, allis chamlers, Mahindra
Wanted to see if anyone has ran into this problem on their 5035. I was greasing the ML130 loader a couple of weeks ago and put the gun on the zerk on the rear top loader arm and it was squirting grease out around it. I pulled gun off and fitting came with it, thought crap I broke it off, but no the hole was over sized and not even threaded! Went to the other side, and same thing, hole over sized and the 1/4 28 zerk was just stuck down in an over sized unthreaded hole! Kind of par for the coarse on quality on these tractors! I know the loader was not built by Mahindra, but tired of this crap on a new machine!
Anyone have any suggestions on the best and easiest way to fix this? I gave up on the dealer helping! Put in a call and can't even get them to return my call! Don't really know exactly what size hole it is, can't get my calipers in there to measure and the rain has kept me from investigating any further. Can you get larger zerks that will fit my gun? I have mostly dealt with the 1/8 and 1/4 size zerks. I know you can get press in zerks, that might be easier as I would not have to pull the loader and pins to get to it to tap it. That is if I don't have to re-drill the hole to a specific size. Can't believe they just stuck the zerks in the holes, they had to know. That was not just an over site!
/ Zerk fittings #2
Amazon, hardware stores, auto parts stores etc will have a selection of zerks in standard and metric threads. Just tap the holes and thread them in.
Not making excuses for the loader OEM but zerks do strip twice in awhile.
/ Zerk fittings #3
Did the zerks that came out have threads on them? I've run into applications (barrel hinges for gates) that have pressed in grease fitting, probably to save labor on threading. You should be able to source suitable threaded fittings, but will probably have to pull all the pins in order to cut the new threads.
/ Zerk fittings #4
Btw- if understanding which zerks this is you should be able to raise the front of the machine enough to allow the loader to lower enough to get the two zerks in without disassembly.
/ Zerk fittings
Yeah, I can raise the front of the tractor and get them back in, but to tap them I will at least have to pull the pins.
Flyerdan, The threads on the zerks were perfect, the holes had no sign that they had ever been threaded and are large enough to just stick the zerks in. The only reason they had not fallen out, was the sticky grease filled hole had them held in!
Rneumann, they were not stripped, I have seen them stripped these had perfect threads on the zerks and no sign of threads in the hole. The hole is probably drilled about 5/16 for a quarter zerk!
I was just wondering If I could find zerk threads that large that would still work with my grease gun end?
/ Zerk fittings #6
If you are unable to use calipers to measure the hole diameter, try drill bits to measure with until you get close within a few thousandths, then compare 1/8" pipe tap drill size to determine if a 1/8" NPT zerk will work. If you can get the drill in position of course. 1/8 NPT zerks are common and that's what I prefer and yes your gun will fit.
/ Zerk fittings #8
I've used a narrow center punch held at an angle to dimple the hole which will close up the clearance and hold a drive in zerk.
/ Zerk fittings #9
The drive in Zerks have grooves that look like threads. I wonder if the OP's have grooves or threads. They may be press-in ones that went into an oversized hole. Or maybe the Zerks were undersized from what was intended. Still should have been noticed when built.
Bruce
/ Zerk fittings #10
When I bought my 5035 back in 2011 I changed those loader zerks to 45 degree ones, so I could grease it easier. I think it came with staight ones. Can't remember what thread size I used, though. Metric or SAE......
/ Zerk fittings #11
If the zerk thread size is metric, one of the possible dimensions it could be M10x1.
/ Zerk fittings
Thanks for all the great replies! I thought I would check the hole against a bit, but I think I will have to get a larger tap set, the one I have I think just goes to about 1/4 and this hole is going to be a bit larger. I had not thought of dimpling the hole, that was my concern was finding one that would fit the existing hole. I will probably put in 45 degree fittings so I can get to them without having to lift the front of the tractor to open it up so I can get to them.
Again, thanks for all the great comments, I will let you know how it goes when I get a chance to try and fix it. Just had my first granddaughter so I have been a little distracted!
/ Zerk fittings #13
Take your 1/4-28 tap and pack the flutes with grease and tap away. The chips will be contained in the grease and won't enter the pin area. Done this many times on bearings and oil pan drain plugs.
/ Zerk fittings
Thats the trouble the hole is to large for a 1/4 tap. These are 1/4 28 zerks and they just rattle around in the untapped hole!
/ Zerk fittings #15
I think, that while we all use a 1/4-28 SAE tap, the zerks are actually a small pipe tapered thread [ NPT ]. It you get one hole too big, there are zerks with about a 1/4" NPT tap, about 5/16" or a little bigger.... The standard old timey zerk are probably 1/8" NPT [ pipe is sized by I.D., not O.D. like a 1/4"-28 bolt ] And again, the next U.S. size is probably 1/4" NPT.... You can buy NPT taps and grind the nose flat which will work. If you keep F'n with the hole, eventually you will be going up the 3/8" NPT, then 1/2", 3/4" NPT.... Which at some point you will just weld on a little pipe coupling and screw the zerk into that..... if there is enough metal left... :)
/ Zerk fittings #16
Chances are you won't want to punch it out any bigger than you have to, maybe a 1/8 NPT or a metric might work. Here's a site that shows all the different types for reference.
/ Zerk fittings #17
Thanks for all the great replies! I thought I would check the hole against a bit, but I think I will have to get a larger tap set, the one I have I think just goes to about 1/4 and this hole is going to be a bit larger. I had not thought of dimpling the hole, that was my concern was finding one that would fit the existing hole. I will probably put in 45 degree fittings so I can get to them without having to lift the front of the tractor to open it up so I can get to them. Again, thanks for all the great comments, I will let you know how it goes when I get a chance to try and fix it. Just had my first granddaughter so I have been a little distracted!
Hey congratulations! Granddaughters are the best!😃
/ Zerk fittings
Yeah, got my granddaughter tonight to give my daughter-in-law a little break. They are in from out of state for a few days. Had to cut up a tree from across my mothers drive today, it hung on a bridge and fence in her drive. Had to use the 5035 and forks to get it down to keep from tearing the fence down! Sure helps to have nice strong big toys to work with!
I will get on the zerk project as soon as the kids go back and things slow down. Thanks for all the help and suggestions! I will have to go and see what size zerks and taps I can find. Just don't want to mess it up and have to drill a larger hole!
/ Zerk fittings #19
Make sure you use a bottom tap if your not taking the pin out.
/ Zerk fittings
Not sure what a bottom tap is?
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
500BBL WHEELED...
New/Unused Quick Attach Skid Steer Brush Cutter (A61166)
New/Unused Quick...
2012 Komatsu PC200LC-8 Hydraulic Excavator (A60352)
2012 Komatsu...
