John Deere 2440 too small?
/ John Deere 2440 too small? #1
storytyme
Orland, CA
John Deere 2440
Hello everyone. I recently purchased a used flail shredder/mower. It did not have a manual, but the owner said my tractor should be fine to handle it. Well I use a JD 2440 with a HP rated at 60. I found a manual online for the shredder and it says minimum HP required is 65. So am I out of luck? Just go slower? Not sure what to do and I don't want to destroy the tractor....its a good one. Help please and thank you!
/ John Deere 2440 too small? #2
My IH 584 is pretty much identical to a JD 2440,,,
I can power the JD 390 through pretty much anything,,,
How wide is the flail??
/ John Deere 2440 too small? #3
You will be fine.
When you begin to have difficulty cutting tall grass, take time to sharpen the blades to reduce load on tractor PTO.
The shredder is 8 foot. I will be chopping/shredding brush in my orchard.
/ John Deere 2440 too small? #5
The tractor might start to overheat in the middle of the summer, at least here in Texas. My dad pulled his round baler that the manual states 85 HP minimum with a 65 HP tractor a couple times in a pinch. It was no big deal as long as he kept an eye on the temp gauge. It's probably actually good for the tractor every once in a while to work the snot out of it. Get all the carbon build up out of the engine.
I say don't worry about it.
/ John Deere 2440 too small? #6
I ran a 7' old Ford 917 flail behind my L3200hst (25hp PTO) & it ran fine. Had to go a bit slower than with my 5' rotary but covered more ground while being easier on me & the machine. I'm a fan of going wide & going slow.
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
John Deere X380 Riding Lawn Mower (A66285)
John Deere X380...
Massey Ferguson 2605 (A64126)
Massey Ferguson...
211298 (A62131)
211298 (A62131)
(2) Wood Pellet Grills (A64127)
(2) Wood Pellet...
2019 JOHN DEERE 325G SKID STEER (A65053)
2019 JOHN DEERE...
