Backhoe 555 TRAN/DIFF FLUID LEVELS
   / 555 TRAN/DIFF FLUID LEVELS #1
berky
Member
Evansville, IN
ford 4500, 555B
Changing fluids on a newly acquired 555B. Refilled trans with 134A to full mark on stick. Did the same for the diff using the rear stick. When I went back and checked the trans stick it was way overfull. I think I have read that the trans/diff are interconnected, but wondering which dipstick is wrong. Anybody out there know or anybody with a 555 that can measure the front and rear dipstick markings length and let me know what they are?
   / 555 TRAN/DIFF FLUID LEVELS #2
Transmission and rear end are not tied together. Did you run the tractor after filling, but before checking the second time?
Thanks TractorTech. Must be something really wrong then. Had to lower the trans fluid level to complete some other work. When I refilled it I put the fluid in the rear filler neck and it went to the trans.
2018 Ford F550 Chassis (A55973)
2018 Ford F550...
2009 Honda Pilot SUV (A55853)
2009 Honda Pilot...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
2007 STERLING A9500 DAY CAB (A57880)
2007 STERLING...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
