Best source of 12V power for third function remote LS 4046
   / Best source of 12V power for third function remote LS 4046 #1
Kubota3710
Northern Alabama
LS XR4046 Kubota G1800
Installing the W.R.Long 3rd function remote. Anyone alreadyi found a convenient source of power for the joy stick? 10 amps desired. Thanks, Rich
   / Best source of 12V power for third function remote LS 4046 #2
I tapped off the keyed wire on the back of the ignition switch for my added lighting. Easy to get to. I bought inline fuse holders at auto parts. You can fuse them any size.
Thanks. That confirms what I was thinking. There is a post on the ignition key that goes hot when the key is turned on. I am planning of tapping into that with a fused wire to power the remote valve.
In case others want a source. ON the back of the ingnition switch are 6 posts. 3 were used, and one of the other 3 provided 12V when the key was turned on. Used it to power the 3rd function, and is working fine. The YELLOW wire in the pic is the one that provided a 12V source. Fused the wire down to the 3rd function valve.
   / Best source of 12V power for third function remote LS 4046 #5
My preference would be to use the switched source as the trigger for a relay. That way you are only pulling minimum current through the ignition switch.
so I understand that a relay would be the best. Not sure what to buy to do that. I'm assuming I would run a wire from the battery to the relay and charge the relay through the ignition switch. Do you have recommended parts for that? I am certainly willing to rewire for the long term benefits.
   / Best source of 12V power for third function remote LS 4046 #7
You can get a single pole dual throw (spdt) relay at your local auto parts store for cheap. Here is a simplified wiring diagram. Hope this helps.
Jaydee325. Thanks for the info That is pretty straightforward. I will put that on my list of upcoming projects. Since I will fuse the circuit at 10 amps, I'm assuming I can use a 20 amp or 30 amp relay, as the fuse the restrictive factor. That sound correct? Again I understand the relay circuit, just actually have never done one. Thanks, Rich
   / Best source of 12V power for third function remote LS 4046 #9
Get one with the built in diode to prevent back EMF from the field collapsing.
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
2025 GPS Equipment Trailer (A56859)
2025 GPS Equipment...
Toyota SR1-BET35 3,500 LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
