Tire Pressure?
/ Tire Pressure? #21
On my 10k trailer the tires say max pressure 80psi but I'm rarely over 7k so I run 60psi which still gives me 10k worth of capacity according to the load index vs pressure chart I have and the ride is a lot smoother. If I know I'm going to be running around pretty light like just making some trips to the lumber yard I'll run them at 40psi which still gives 8k worth of capacity but you don't need to see a chiropractor after a trip like you would running 80psi and unloaded. It's not a balance issue in my case it's called stiff suspension plus stiff tires plus unloaded trailer that's more prone to flexing means you're gonna feel every crevice in the road. Now granted the vast majority of my trips are 10mi or less and if I was going longer distances I might be more vigilant about running higher pressures like I do on my maxed out single axle (**** you Triton!) boat trailer.
As far as the truck tires go I run 42f/45r (275/55/20) on my 2016 F150 regardless of load unless I'm maxing out my trailer then I might bump it up a little.
/ Tire Pressure?
Agreed. I'll recheck mine to see if they have been balanced. But, on a smooth road I feel nothing. But, if they have not been balanced I'll probably do it anyway. Can't hurt.
/ Tire Pressure? #23
Not trying to give advise or claiming to be an expert on the subject but:
I have towed a 3500lb car on my 18', 7500lb capacity trailer for thousands of miles with a 2003 F150. I leave my truck tires at 32 and set my trailer tires at 50. I ran the original set of tires for 9 years without any failures and replaced them with same load range and size tires that came on it. The last haul I did with the old tires I noticed one tire looking bad when I set the pressures so I put the spare on for that trip. Ordered 5 new tires as soon as I got home. None of my trailer tires have been balanced. They bounce a little when cold on an empty trailer but seem to smooth out on the highway.
/ Tire Pressure?
Who do you run with? I instruct with NASA SE. Haven't done TT yet. Probably won't ever race WTW.
/ Tire Pressure? #25
Haven't done much of anything in a while but I have run some HPDE with NASA SE at Road Atlanta and Roebling Road. Ran Sebring one time with NASA FL. I have just stuck with HPDE3. I am comfortable there and not in the way. Done a few Advanced PDX events with SCCA.
Here's a few videos.
/ Tire Pressure?
Its an addicting (and expensive) hobby. I run 4-5 times a year. I like the auto-x videos. I've never done it but would like to try it sometime. In NASA-SE DE-3 and DE-4 are almost the same since 3 and 4 run together most of the time.
/ Tire Pressure? #27
I have run autocross since the mid 70s. It's fun but not a particularly good value. Cost of events has gone up to 40-50 bucks for 5 minutes of seat time. Spending $1500 per year on tires and working in the hot sun all day for that little seat time doesn't make a lot of sense to me any more. I still make a few events for the comradery and they usually let me work as starter so I can sit and do that.
I just retired so future events may not be in the budget. Have been debating on selling off all those wheels and tires in my shed.
I built up an old late model to get cost down and only did two track days with it in a years time so I sold it but tires for the Mustang are out of sight.
/ Tire Pressure?
I've gotten a lot of wear out of Hankook RS-3s even on my home track (Carolina Motorsports Park) which is really hard on tires. VIR is pretty easy on tires. My biggest expense is brake pads.
I'll put in a plug for instructing: it saves you a lot of money. It also takes the pressure off the weekend since you haven't paid an entry fee. Now, if I feel like going out, I do. If I don't feel like going out, I don't. When I was paying $400 a weekend I felt pressure to be on track every second I could. I went from DE-3 to DE-4. Ran maybe one DE-4 event then took the instructor clinic and haven't paid for a track weekend since then. It has allowed me to continue to do it because like you say, it can be cost prohibitive.
But, you can't do it just for the cost savings. You do have to enjoy instructing and you have to commit to making the weekend worthwhile for your student. I wasn't sure I'd like it but I do. And so far, I have had good students. One of them was a bit irritating (big talker) but no problems in the car.
/ Tire Pressure? #29
My last autocross I just drove up on my Nitto street tires and street setup and had a good time. Would never do a track day like that but might consider some less expensive tires than I usually run and get up for an outing.
I came across some street performance brake pads that have held up on track without fade and cost $75 for both axles. They are a Kevlar/Metallic compound made by Lomandi, a Canadian company. They require cooling ducts to hold up on track but perform very well on my Mustang. I even put them all the way around on the stock car and they did pretty good but I never drove it above 7/10ths. I had an issue with my cooling ducts coming loose at Sebring one time which is very hard on brakes to begin with. I ripped the ducts off and kept running to find out the pads were wearing much faster even though they didn't exhibit any fade. Wore a set out in 7 sessions and over heated the calipers. Not sure how they would do on a 150+ MPH car but I was touching 145 coming off the back straight at RA and they worked fine for me.
I considered the instructor route early on but didn't think I would feel safe with a total beginner in and unprepared car. Having done so few events lately and reaching medicare age they probably would not allow me in the instructor class now.
My first instructor was a PITA Porsche owner that kept his finger in front of my face pointing out the line all weekend. I learned a lot from him but he didn't do any evaluation at the event and got some points totally wrong when he was pressured to fill out my evaluation at home.
My second event I requested a Corvette or Mustang driver if they had one. Got a great instructor that drove a vette. He signed me off to solo and move to 3 after day 1. Have thoroughly enjoyed all the track days I've done after that.
Didn't mean to hijack your thread but thought you might like to hear my towing experience since it's near your setup.
/ Tire Pressure? #30
Oh yeah, I balance my trailer tires too...and man I've gotten some strange looks from folks over the years when I walked into their tire shop and asked for trailer tires to be balanced. Was more just debunking a lot of the posts that were quick to jump to a balancing issue versus taking all factors into account (high pressure in tires and lightly loaded stiff springs). I didn't feel like cleaning out my truck so I pulled my trailer about 250mi round trip this past Monday to go pickup 1 1/2 cows worth of meat. I used my FEL and sat my 5' bush hog over the axles and chained it down just to load the springs a little and make the ride smoother. LOL!
/ Tire Pressure? #31
I'm another vote in the balancing trailer tires group. Used to deal with a lot of uneven tire wear on boat trailers from them bouncing around, balancing pretty much stopped that. On campers, if the tires aren't balanced, you never know what the inside is going to look like you get to where you were going.
I had one 5x8 utility trailer once that the tires weren't balanced. I used it to haul our camping supplies on a 150 mile trip. When we got there, I opened the cooler (which was on the trailer) and could barely tell the difference between a Bud Light and a Coca Cola! All the vibrations with the cans against the ice had rubbed most of the paint off the cans.
I have taken trailer tires in to get them mounted and balanced and around here, lots of the places tell me that they never balance trailer tires. I always insist.
/ Tire Pressure? #32
It could be argued if one is using something like a ag implement that doesn't ever really hit the road or go over 25-30 mph that balancing is a waste of time. But yanking around a trailer that is doing whatever the pickup is doing, not balancing the tires would be a little strange. I realize that many don't do it, but I like my axle bearings, suspension, and tires well enough that I don't want to subject them to unnecessary abuse. Balancing trailer tires just makes good sense.
/ Tire Pressure? #33
I would venture to guess there are more trailers running down the road with unbalanced tires than there are with balanced.
I use to be in the same camp and balanced everything. Not relevant to trailer towing but I was finally enlightened on my race tires that the tires would rotate on the rim within a few laps. You can draw a line to mark tire and rim location, do a few laps, and it will have moved. Sometimes by a great deal. I stopped spending the money to balance my 315mm wide tires and get very little vibration out of them. I can feel my unbalanced trailer tires bouncing a little when the tires are cold then it smooths right out. I like my money so after getting 9 years out of a set of unbalanced tires I didn't bother balancing the new ones.
On another topic the one thing you better do on any new trailer is retorque the lug nuts. When my trailer was new it had orange stickers reminding you to check the torque after 200 miles. Had I waited that long I'm pretty sure I would have lost a wheel. I checked them every 50 miles until they didn't take any turns to get back to 90 lbs. That original set took 8 to 10 retorques before they required no more tightening. I suppose those cheap wheels were having to bend to conform to the hubs. My new set of same type wheels and tires stayed tight after 3 times. I have to do the same with my car after removing the wheels. I can drive it 50 miles and the nuts will require a 1/4 turn or more to achieve the proper tightness.
2007 BIG TEX 16 T/A UTILITY TRAILER (A65643)
2007 BIG TEX 16...
2016 CATERPILLAR CP44B PADFOOT ROLLER (A65053)
2016 CATERPILLAR...
2015 BMW X1 SUV (A64557)
2015 BMW X1 SUV...
KOMATSU WA270-8 WHEEL LOADER (A65053)
KOMATSU WA270-8...
ATS 13,000lb Electric Winch (A62679)
ATS 13,000lb...
2008 JLG 3246ES 32ft Scissor Lift (A64553)
2008 JLG 3246ES...
