Oil & Fuel Rookie Mistake Perhaps........
/ Rookie Mistake Perhaps........ #1
gltrap54
Topeka,KS
B3200 Kubota
Just completed my first 400 hour service on my B3200..... Used hyd/trans fluid Super Trac Super S 303 Hydraulic fluid from TSC...... Just read the fine print stating it's not recommended for tractors manufactured after 1974..... Hmmmm..... Should I leave it or change to a better suited fluid..... Couldn't bring myself to pay 3-4 times as much for Kubota's UDT..... What advice does TBN have for a rookie? FWIW...... I put 50 hrs/year on my tractor, most of that is lawn mowing......
Oooops.... Now I'm reading the Super S is in fact a "Multi-Service Hydraulic/Transmission/Wet Brake Lubricant"....... :confused3:
/ Rookie Mistake Perhaps........ #2
Change it. You don't want to be wondering if it's wrong for the next 400 hours.
/ Rookie Mistake Perhaps........ #3
Drain it,cheap insurance just not worth the risk
/ Rookie Mistake Perhaps........ #4
I always recommend using Kubota branded fluids/filters in Kubota equipment.If you ever have a warranty problem there will be no question.What are you really saving when under normal uses for a home-owner fluid changes may be every two years or longer.
If I owned JD,Massey,New Holland ect. ,it would be the same advise.
/ Rookie Mistake Perhaps........ #5
Change it to SUDT and don't look back, even non Kubota tractor owners commit on how good it is for the hydro noise on cold start ups.
DevilDog
/ Rookie Mistake Perhaps........ #6
Change it and drain it thoroughly.
I have a truck and put the trans fluid the dealer told me. I went from Dexron 3 to Dexron 6. From reading on forums and reading experts advice I wound that seals in my year of truck were such that they would start leaking in time if Dexron 6 stayed in. The reason being is they used a certain type of o-rings that don't hold up for a long period of time, so I went to a synthetic oil for my Allison trans.
I drained it, filled it, ran it 50 miles, drained it again and refilled with a certain synthetic oil. I don't know why your oil isn't recommended for previous years, but the reason might cause a substantial bill down the road.
/ Rookie Mistake Perhaps........ #7
Relatively a few dollars now to change it. Perhaps changing it is not needed. But if it is needed your looking at a LOT of money down the road. Even with the equipment just setting the wrong fluid can affect types of rubbers and gaskets and seals. Not need to even be running. Figure in labor to have service done to your equipment and have it to transport it and your probably still breaking even this time with changing the fluid. Lesson learned and on you go.
/ Rookie Mistake Perhaps........ #8
Kubota SUDT-2 is highly recommended by both Kubota and many, many owners who say it makes a real difference in the performance of their tractors (including me!). You have a very nice tractor that is nearly all hydraulically operated. Use the right fluid to keep it running a long time.
/ Rookie Mistake Perhaps........ #9
I used to have a B2920 that had a very noisy HST whine. After the first 50 hour change with SUDT-2 it was quieter and seemed to improve a little more over time.
I'm curious if you started/ran your tractor at all with the TSC oil, and if so, how did it sound?
/ Rookie Mistake Perhaps........ #10
Run it til it quits, seriously, good fluid is cheaper than another tractor.
Ronnie
I did run it briefly...... To the untrained ear, it sounded fine...:eek:
Thanks fellas for your input! I'm on my way to the dealer to pick up the UDT! Lesson learned!
/ Rookie Mistake Perhaps........ #13
The doom and gloom on internet forums is entertaining.
While I'm not a chemical engineer, I am a mechanical one and have designed various sealing widgets.
No seal is perfect, nor is chemical compatibility. I, too, run SUDT. But crikey, at the end of the day it's just a hydraulic circuit.
One product I worked on used Dextron III in a hydraulic circuit (with similar-ISH industrial pumps, compensators, motors, etc).
Dad runs Ford oil and has for 15+ years. I dislike the "i've been doing it for xxx" statements because they don't prove anything, but it goes to my point. It is NOT all doom and gloom. I've even <gasp> switched from dino to synthetic and back to dino in one of our cars. Oh the humanity!
Mostly I agree with the "cheap insurance" comments. That said, over the lifetime of a tractor thousands could probably be saved. That's another implement, or a few car payments, or whatever. Bottom line is that we can all "nickel and dime" ourselves into the poor house. We all choose to save in some places and splurge in others. I will *not* give you a hard time about buying off-brand oil. I doubt you'd ever notice, especially if it's mostly summer use. I use mine for blowing snow for 1/3 of the year, so I wanted synthetic. I like *all* types of synthetic oil. I even ran synthetic in my Boss plow, when I had it.
So on the forum where we all blab our opinions and argue it like facts.....that's mine.
Carry on!
/ Rookie Mistake Perhaps........ #14
I have used tractor supply's premium UTF in my B2710 in the past. Trans whine was louder until warmed up but never had problems, switched to sudt2 and it sounds like a sewing machine.
I would change it out and use the premium UTF if you do not want pay for sudt2.
/ Rookie Mistake Perhaps........ #16
Carry on!
The hydraulic circuit part is one thing, but transmission components, PTO clutch discs, and brakes submersed in it are something else entirely.
/ Rookie Mistake Perhaps........ #17
I'd be curious (but not actually enough so to *do* it) of the actual specs. I haven't decided if I agree, or not. The alternative is either compatible, or not compatible. Regardless, I think we're talking degrees of good vs. the doom and gloom of the first page+ of this thread. That was my point.
Similar to the Sprint (I think...I have a DVR so commercials get skipped) ads against Verizon where they talk about twice as much money for 1% better.
Again, I also run SUDT. They're proud of it though, and I think I use 11 gallons. It's a lot of coin. I also make sure to run the block heater when it's cold. I also run synthetic engine oil. If I'll actually see the benefits of these good deeds........who knows.
/ Rookie Mistake Perhaps........ #18
I certainly won't argue with that. I've seen mention of people running "compatible" or acceptable alternatives and having brake chatter and/or shifting problems that went away when the recommended fluid was replaced.
In some cases there has been gloom and doom documented. I've read a number of horror stories on the Case/IH forum about folks substituting something else for the recommended HyTran Ultra and having to replace every fiber disc in the system. Similarly, I've seen a retired Case tech talk about a variety of problems he could only trace back to different fluid. I'm sure not 100% of those are really the fault of the fluid being different, but there were enough I thought it wasn't worth risking it when I changed the hydraulic fluid on my backhoe, and that was something like 20 gallons (you replace just what's in the tank) at $100 per 5gal bucket :eek:
/ Rookie Mistake Perhaps........ #19
A manufacturer cannot deny you warranty work if you do not use their brand of oil. They can and will if you don't use the oil with the specifications they require.
I worked at a heavy equipment dealership many years ago. They did not sell the manufacture branded oils. They used a local lubrication distributor that provided the correct specification lubes. Zone reps for the manufacturers never seemed to care that we did not sell the branded oil.
Bottom line, make sure if you are buying off brand, that it meets the specifications provided by the manufacture. And keep your reciepts!
/ Rookie Mistake Perhaps........ #20
Guys keep in mind that it said right on the container he bought. The fluid was not for OEM equipment after 1974
2012 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2012 Chevrolet...
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
CASE INTERNATIONAL 230 - 35' TURBO TILL (A63291)
CASE INTERNATIONAL...
2015 John Deere 8270R (A64119)
2015 John Deere...
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
