2210 jd will not start blows 20 amp fuse when key is in the run position
   / 2210 jd will not start blows 20 amp fuse when key is in the run position #1
bmryer
dallastown pa.
2210 john deere
2210 jd will not start blows 20 amp fuse when key is in the run position must be a short where to start Thanks
   / 2210 jd will not start blows 20 amp fuse when key is in the run position #2
I would rig up a light that you can plug into the fuse socket. If there is a short, it will light up and stay lit until you can poke around and find where it is shorting out.. be it a switch or a bad wire grounding out somewhere.
I solder a couple wires on a light socket to a blown fuse that goes into the fuse holder.
:welcome: to TBN
:welcome: to TBN
12 volt light, will that blow the light
   / 2210 jd will not start blows 20 amp fuse when key is in the run position #4
No,, you just keep poking around until the light goes out,,, or dims less than full bright.
if the "short" were not there, the light would not be "full bright",,
normally, the light would barely glow, if it lights at all.
   / 2210 jd will not start blows 20 amp fuse when key is in the run position #5
Find my Deere 5520 won't start thread and see if this is the problem with yours. It's a shorted sensor on tractors that have a cold start package. Not sure if yours does but you should be able to figure it out from the parts diagrams. If this is the problem, and I suspect it may be, it's an easy fix.
Advise if you can't find it.
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
Hose Reel (A55787)
Hose Reel (A55787)
