Sweating metal building. Exhaust fan???
   / Sweating metal building. Exhaust fan??? #11
Just one of the reasons I moved away from Louisiana to the desert southwest. The humidity in New Orleans was too much for me, best thing I did was get out of there. I do miss the food and my old friends though.
   / Sweating metal building. Exhaust fan??? #12
What do you have for a floor? I'm guessing gravel? With the stream that close I'm guessing you some pretty moist soil under the building. Grab a shovel and scrape away the gravel so you can see the dirt underneith. Dig out a little and see how damp it is. If it's damp, you know your moisture source. At this point, you have a couple of options. Ventilation will definetly help, but you are only removing the moisture present, not eliminating it. This method will work if the stuff being stored in the building won't be damaged by the moisture. Personally, the best way is to eliminate the moisture at it's source. In your case, I'd suggest putting a vapor barrier down on the floor. Many will use 6 mil poly as a vapor barrier, however it's very prone to being punctured by the gravel. An upgraded product is called Stego Wrap. It's a very thick, very durable vapor barrier that won't fall apart when you drive over it. I'd suggest taking the gravel out and then putting the vapor barrier down. When you put the gravel back try to target at least 6" of gravel. This depth of gravel will help protect the gravel from spinning tires and such.
The floor is all concrete with a moisture barrier under it.
Sounds like venting to keep the inside /outside temps equal is the only option. Guess ill get a fan on order and see what happens. Once again, thanks for the help.
   / Sweating metal building. Exhaust fan??? #14
Questioning the balancing the temp issue. I have a chicken run as a lean to off one side of a large shed. The roof is metal and the sides are open but have fencing to keep the chickens in, predators out. I get condensation all the time on the metal roof. Since the sides are open, the temp inside is the same as the outside temp. So I don't have a venting problem or an unequal temp problem. But I get wet roof many mornings.
My experience with this metal roof is causing me to shy away from a larger lean to off my barn that I will use for equipment storage - camping trailer, 6x10 trailer, car transport trailer plus zero turn, lawn tractor and wood splitter. I don't want water dripping down causing rust on the equipment. Seems plywood and asphalt shingles don't have this issue.
   / Sweating metal building. Exhaust fan??? #15
The venting idea is sound but the reasoning, as stated, isn't. You are not trying to lower humidity with ventilation. You are trying to balance temperatures. If OP's tractor or metal object was outside I'm gathering he does not believe it would form condensation. The reason is because the temperature of the object is rising at or near the same speed as the air.....no condensation.
Move that object inside the barn and things are different. The solar gain on the structure heats the air inside the structure faster than the object (which receives no solar gain). When this occurs the object will form condensation from the temperature difference between the air and object.
The goal with moving air (mechanical or natural venting) is to mitigate the solar gain which will slow the warming process inside.
So, beyond the big ticket obvious exterior moisture issues like proper drainage around the structure, the goal is to slow temperature change. If the goal is to lower RH the OP needs to seal the structure and mechanically remove moisture.
Thoughts on a solution-
With an insulated structure this could go either way. Vent or not vent. It's time to experiment.
First air the place out to balance RH between inside and outside. Then leave 2 roll up doors on opposite sides up overnight and see if condensation forms. If not, continue to lower the doors daily until it does. This will give you an idea how much venting you will need. Assuming you don't have a good predominate wind from a different direction. The vent sizing can be slightly less if you are using the low and high venting suggested by a few folks as this creates some natural convection.
However, I'd also try this since it's insulated. Maybe the insulation can slow the temperature change enough that having the holes in the doors is the issue. In this scenario the goal would be to make the structure as air tight as possible. To do this the starting point is the same with airing the structure out to balance the RH. Then seal up the openings in the roll up doors and any other major sources of air infiltration. See what happens the next day. Maybe, just maybe, the insulation is slowing the temperature changes enough to prevent condensation.
Both of these experiments will cost little to nothing except some time. If objects outside aren't condensating but objects inside still are with doors fully open or everything sealed then it would be time to think about a fan on a switch that is reading temperature differences.
Guess we are on opposite sides of the fence. You need 2 things to sweat, moisture and temperature differential. Moisture comes from the ambient air with respect to dew point and temperature determines your objects relation to the existing DP. If the interior of the building has accumulated moisture and objects including ambient air are below the DP moisture in the air will condense. If the temp is above the DP the moisture will stay in the air.
Perfect example is face mask when welding. Moist exhaled air is hotter than mask on a cold day. Moisture condenses and foggs mask. Take a hair dryer and blow it on the mask and condensation ceases.
   / Sweating metal building. Exhaust fan??? #16
The metal holds the overnight temp longer than the ambient air as it's displacement is heavier, requiring more energy to heat and adequate convection heating in this case, for it hasn't occurred. It's cooler than ambient air, moisture in the air condenses on the cooler surface. As I said, I have the same problem with the leanto on my shop.
Another example is the air conditioner. Cold evaporator coils collect the moisture passing over them since they are colder than the air. The moisture doesn't collect on objects in the room as they are warmer than the air being refrigerated. If you have a glass of iced tea on the table, it will condense the water in the air adjacent to it as it is colder like the cooling coils. Had there been no moisture in the air it wouldn't/couldn't sweat.
   / Sweating metal building. Exhaust fan??? #17
The problem I have is the humidity all winter long in CT is 60-100%. Right now it is 30 out with 89% humidity. Heating the equipment shed is not an option. So should I avoid a metal roof knowing I don't want condensation dripping on everything? The inside of my barn never has the condensation issue, it is a typical New England barn built of wood in the 1800's.
   / Sweating metal building. Exhaust fan??? #18
Hello BoylermanCT, I have an uninsulated corrugated iron clad woolshed. Most mornings, inside the shed it "rains" as the condensation runs down the iron and onto the purlins , then drips on the floor. The solution is to use waterproof roofing "paper" designed to stop this problem. I used the silver version so the light is reflected off the ceiling (the black version swallows light and makes things dark). So, dry shed and better lighting. I get 80" anually and a heavy dew most days.
   / Sweating metal building. Exhaust fan??? #19
You should avoid a metal roof exposed on the inside. Glue/spray a thin layer of insulation inside and a metal roof should do fine. Like slipping a cold pop can into a koozie.
   / Sweating metal building. Exhaust fan??? #20
Insulate under the roof and keep vents open if you have them
STRICKLAND CASE 621D WHEEL LOADER FORKS (A52705)
STRICKLAND CASE...
UNUSED FUTURE JBD 32" MINI HYD MIXING BUCKET (A54757)
UNUSED FUTURE JBD...
Red Military Truck (A53422)
Red Military Truck...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Fork...
Galvanized Livestock Gates - (6x Total Gates) (A55218)
Galvanized...
