Winter Projects 2016-2017
/ Winter Projects 2016-2017 #1
SJay
Gold Member
Tri City Area, MI
Bobcat CT225 Tractor, John Deere 4x2 Gator, Husqvarna Zero Turn, John Deere Buck 650 ATV
Thought I would start a thread on things we are all working on this winter - I am taking 2 brush hogs and making one. Frame from one, gear box from one, stump jumper from one
/ Winter Projects 2016-2017 #2
Nothing on tractors or equipment at the moment, but will be working on the Grandson's motorcycle. 1986 Honda Nighthawk needs a carb rebuild and sync, the brakes gone through and a leaky cam cover gasket replaced.
Looking it at, it's gonna take most of a day just to get the carbs off...
20161125_143850brush.jpg20161125_144146brush.jpg20161125_144542brush.jpg20161125_144553brush.jpg20161125_151504brush.jpg20161125_151518brush.jpg
/ Winter Projects 2016-2017 #5
Working on finishing our basement. This will be the 3rd winter I've worked on it for crying out loud. Limited skills, funds and brains are creating some issues, ok, a lot of issues. But, I'm close as I'm down to hanging Sheetrock.
Keep the sheetrock 2" off the floor (water) - your baseboard will cover it.:thumbsup:
/ Winter Projects 2016-2017 #8
I have a list of projects that I've started, so finishing just one of them would be an achievement. Siding my house, building a back porch and a new back porch. Finishing chicken coop number three. Finishing gazebo number one. Finish clearing my fence line. Removing two massive oak trees with three foot thick trunks that feel across where my fence is going to be.
Fortunately, I should be done with a quick and easy greenhouse lean to project tomorrow.
/ Winter Projects 2016-2017 #9
I'm setting up a new SWT Skandic for work right now. That's a work snowmobile. Also building, or at least sealing up since I'm confident I'll not get it more done before serious snow arrives, a 14 x 20 skid shed. What else???
Starting to get the Brush Hog put together - tested it today - now on to paint20161223_143749.jpg20161223_143818.jpg
/ Winter Projects 2016-2017 #11
Wire in new backup lights on the Jeep with a separate switch.
Install new rear facing work lights on tractor.
In spring, a new sliding storm door for the front.
/ Winter Projects 2016-2017 #12
Got several areas to address on my recently acquired 1930 Chevrolet to prepare it for enjoyment in 2017. It had been sitting since about 2004, and had to clean out the fuel tank, repair fuel pump, and install some correct parts to get it running. Will likely install a 6 volt alternator to improve upon electrical system performance, and some subtle turn signals.
Got a ton of other projects to complete before Spring, too, such putting casters under my sandblast cabinet and removing all the shrouds on the Wisconsin engine of my wood chipper to make sure it's clean so it doesn't overheat.
/ Winter Projects 2016-2017 #13
working as a handyman for others to finish THEIR projects just leaves me little time for my own projects these days... how sad. Now i gotta figure out how to pay myself so i can actually finish all the gadzillion things i want to finish......:confused3:
/ Winter Projects 2016-2017 #14
I have few too. Priority is to finish the greenhouse. I have it about 75% completedfront wall just needs the double doors, entire back wall needs to be sheeted, and one end gable to finish off. Also need to re-make a sign for SIL for their camper, create another 2 for 2 other family members for their respective campers.
Replace battery in tractor, last time I started it, itbturned over really slow before it caught. And seal up gaps in vapur barrier in crawlspace tp prevent humidity from coming in from the ground. This will be very time consuming.
/ Winter Projects 2016-2017 #15
Redid our kitchen last year, which involved moving all my woodworking tools out of half the woodshop so they access the basement ceiling to redo the heat on that side of the house.
So this year, I am trying to put it back together in a way that is a little more usable and makes more sense.
That means making better spaces for the powertools so they are all at the same workheight and can share infeed/outfeed surfaces, and adding dust control. We are currently in the "make a bigger mess before you can reduce the mess" stage. I am trying to figure out storage options I will use besides the default of "leave everything on the bench and paw through it" which is my habitual default. I am not completely convinced I can avoid that completely, but having easy spaces to put things where they go that I can actually get to and use helps.
/ Winter Projects 2016-2017 #16
Had to redo my shop last year because of mold issue. I had to call a contractor to take out the bottom 18" of wall, then pour a new concrete wall under the existing wall. When I put it back together, I built some cabinets along the back wall for the small power tools. In the middle I built a rolling cabinet for my miter saw. The saw stand is lower so the counter top works as supports for the long pieces. All the big power tools are on wheels so they can be moved if needed. I'll try to post some pics a little later
Got most of the Rotary Cutter doneBrush (2).jpgBrush (1).jpgBrush (3).jpgBrush (4).jpgBrush (5).jpg
Sorry about the picture rotation
/ Winter Projects 2016-2017 #18
finishing up the pig roaster gotta get the iron cut to weld up a handle then paint.
2013 Keystone Springdale Camper (A62613)
2013 Keystone...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
Husqvarna YTH24K48 Riding Lawn Mower (A65579)
Husqvarna YTH24K48...
New/Unused Wolverine 84in Quick Attach Smooth Bucket (A65583)
New/Unused...
2018 JOHN DEERE 60G EXCAVATOR (A64277)
2018 JOHN DEERE...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
