rotating spiked ice breaker
/ rotating spiked ice breaker #1
crazyal
Super Member
Northern Vermont
Kubota, Case, Deere
I'm thinking about making one of these (but much smaller).
I'm thinking of making two 18" wide spiked wheels. I figure I could use two pieces of 12" pipe with plates welded on each end with flange bearings on each end. Each one would be articulating enough to make up for unevenness of the road. It will be 3pth hitch mounted so it'll have to have enough weight to break up the ice on the dirt driveway. It would look kind of like a harley rake but not powered and not the full width. What I haven't figured out is what to use for teeth. I would like find some that are threaded so they could be removed when they wear. Does anyone have any ideas?
Here's a look at a different brand. These are make for highway use by much heavier equipment moving at much faster speeds. This one just looks like you replace each wheel when they wear. One of the mfgs say they last 5 years but that seams overly optimistic unless they are harden steel.
1430125143128_bulletin
Here's a youtube:
/ rotating spiked ice breaker #2
A great idea (making one), but maybe you could just find an old (and cheap) 3 point rotary hoe. They are fairly heavy and have lots of sharp rotating tines.
Or- how about buying a set of chains for the tractor rear tires- perhaps they would break up the ice fairly well so you could just ed up making 3-4 passes and offset the tire track each time.
I haven't seen anything used that would work. I do have some ice pick chains but they only do so much. They have 1/2" diameter rods for spikes but are only 3/8" of an inch long and the face is flat. By making something I could use spikes that are pointed and I could put a lot of weight on top of the spikes. I don't know if the smaller diameter of the wheel vs the tractor helps break the ice up. I was thinking if the spikes are spaced out a little bit it would give it a hammering effect to also help break the ice up.
/ rotating spiked ice breaker #4
Seems like, unless it's vibratory, it will need to be VERY heavy. :confused3: But definitely following.
It'll be a summer build, too cold here now without a heated garage. Our weather tends to be above freezing for a day or so with enough rain to turn the snow into a soggy mess. Then it's followed by a deep freeze, usually below zero. That sets the ice up like cement. Right now I use the ripping teeth on my grading scraper and the chains on my rear tires to break it up. It works but neither is really made to do it. Usually what works the best is putting the tractor in 2wd and using the split brakes to have a tire spin and dig into the ice. It's time consuming and not very accurate.
I'm hoping that I spread out the spikes far enough it'll have some bounce to it. I think I can adjust the speed I drive to maximize the bounce. I'm thinking that it'll have to be loose so the lower arms aren't also bouncing up and down. I haven't really seen anything like it the size I'm thinking about. Everything is much larger so it's going to be build it in the summer then trial and error to get it to work next winter.
I'm wondering if I use a cold drawn rod, say 3/4" or 1" in diameter for the spikes if that would work and last. If needing replacement I would have to torch them off and grind off any remaining weld. But I should be able to make the teeth like in that middle picture. I don't have any thick wall tube so I'd have to buy it. I'm thinking I could end up with $400 (or more) in steel into this so I want to plan it out.
/ rotating spiked ice breaker #7
Disk harrows with spikes welded on the pans?
Or just spread some gravel/sand...
I don't think a lawn aerator would be strong enough. To work it'll need at least 1000 lbs on only a few spikes at a time. But I have only seen the plug style that cuts small holes in the lawn and removes a plug. Gravel actually doesn't work all that well unless you have a lot of money. When the ice gets smooth it just slides off after one or two cars try to stop unless you put a lot of it down. A town can afford to put it down thick enough, I can't. Mixing in salt helps to a point but it adds up when you have a mile long drive and if the temps drop enough salt doesn't melt. The third, and biggest problem is that it's only good until the next snow storm. Either you plow/ blow any loose sand off the drive or it gets covered in enough snow that the sand is covered with a layer of snow that will turn to ice during the next melt. Each year I get a 18 yard load of sanding gravel from a local company. About mid January it'll freeze up solid. Usually it's not too big of a deal because once that happens we don't normally don't get a thaw that'll turn any snow on the drive into ice.
/ rotating spiked ice breaker #9
Can you get the same gravel with 10-15% salt added for a reasonable price? AKA 'sweet mix'
/ rotating spiked ice breaker #10
Ice build up that bad?
Time and $$$'s compare to load sandy gravel or good set Canadian tire chain like the ones use on skidders.
/ rotating spiked ice breaker #11
Just some more options.
The first one should be interesting! The last one most easily tried. The in between ones come in different sises. Pulling uphill may be an issue with the last three.
/ rotating spiked ice breaker #12
Dude! I'd love to see a video of that first one in action!
Hadn't though about putting land mines in the driveway. Bet they would clear the ice no problem. Of course finding enough neighbors to come over might prove difficult.
It's not the tractor, I have great chains for it. If I was retired and could take care of the melting snow as it's happening it wouldn't be much of an issue. But working a 12 hour shift means I can't always get out there and deal with it before it becomes a problem. Nobody around here offers gravel with salt. The town buys the two separately and mixes it themselves. I do have a herd sander to put it down with but even that is a lot of work. Just filling the hopper is a workout then the sand likes to freeze inside the hopper (because the temp has dropped). If I could connect up to something and just drag it up and down the driveway and let the tractor do the work then I'll be happy.
Egon those middle two are kind of what I had in mind but just less spikes and with weight above them. The two "wheels" would be spaced further apart to about the tread width of a car.
/ rotating spiked ice breaker #16
Looking at that second pic, how about a 45 gallon drum filled with cement, and then driving rebar spikes into the sides before it dries. Should be plenty heavy or a two foot diameter pipe instead.
/ rotating spiked ice breaker #17
Great idea- relatively cheap and fairly easy.
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
Towable Pipe Road Crossing Trailer (A63689)
Towable Pipe Road...
2025 Safety Basket Forklift Attachment (A61572)
2025 Safety Basket...
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
2012 VOLVO ROAD TRACTOR (A64280)
2012 VOLVO ROAD...
