Coupling a one-way cylinder to M9000
   / Coupling a one-way cylinder to M9000
Don't want to start a new thread, but have another hydraulic question.
I'm in a project now, where I need to connect two (in parallel) Double Action cylinders to a Remote Valve on a tractor. Although both cylinders' travel end positions are matched with the end positions of a mechanism, do I still need to think about Relief Valve installation?
I'll try to explain my way, why I'm asking.
I'm sure (and I hear) a Relief Valve properly works within Remote Valve operation. But if, for example, I'll dig the earth, my mechanism may sometimes stick in the earth (within the range of the cylinders), and because of overload the hydraulic pressure will increase. Won't the cylinders break my mechanism, until a Relief Valve of a Remote will be engaged? I just want to protect my mechanism from breakage by the cylinders.
Thanks in advance for the advices.
   / Coupling a one-way cylinder to M9000 #12
The relief valve on the tractor will protect anything being operated. As you noted, it won't protect anything that isn't being operated at the time. If you put a crossover relief valve like on a snow plow, it wouldn't work. The rod end & but end of the cylinder have different volumes so tying them together in an over pressure situation wouldn't let the cylinder move. You'd need a valve that dumped to tank when an over pressure situation occurred. That would mean running an extra line as there is no way to tap into an always on tank line with a standard double acting spool that's on all tractors. I believe skid steers often have a 3rd line plumbed in for a case drain on hydraulic motor implements, but not tractors.
Thank you, Fallon. So I should rely on a physical strength of my mechanism built (or to strengthen it, if necessary so it wouldn't be broken), as well as on a Relief Valve of a tractor. And that's it.
   / Coupling a one-way cylinder to M9000 #14
Thank you, Fallon. So I should rely on a physical strength of my mechanism built (or to strengthen it, if it's not enough) so it won't be broken, as well as on a Relief Valve of a tractor. And that's it.
Either that or invest the time & money to build the required relief mechanism to operate when the control valve isn't being actuated.
Dilemma...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2005 Pierce Enforcer Fire Truck (A50323)
2005 Pierce...
Great Plaines 2400 Tt (A50514)
Great Plaines 2400...
2018 Dodge Ram 5500 Bucket Truck - 4x4, Versalift VST40, 45FT Reach, Dakota Line Body (A51039)
2018 Dodge Ram...
1999 INTERNATIONAL PAYSTAR 5000 TANDEM AXLE DUMP TRUCK (A51222)
1999 INTERNATIONAL...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A50397)
2024 BCL...
