Is there a need for a coolant overflow tank?
   / Is there a need for a coolant overflow tank? #21
After looking for a tank I decided to just leave it as is. Why?
- Could not find a tank small enough
- Any "custom" tank would look like carp
- Basically it's not needed
Thanks for the suggestions. I'll just let it pee on the floor and wipe it up till it stops. Anyway it's a great spot for a spare battery tender!
-R
Hit the auto wreckers, there must be a little car that will have a great little reservoir. Probably pretty cheap.
   / Is there a need for a coolant overflow tank? #22
That's a great suggestion! It will already have the cap and hose connections in the right places too.
I have searched for replacement tanks. All are large or custom shapes to fit in small spaces. The idea is not dead just on a lower priority.
Great ideas though.
-R
   / Is there a need for a coolant overflow tank? #25
What about the ones they use on ATVs they might work for you
Someone mentioned the fuel shut off on your tractor. Yours is in a much better place than the one on my 4510. It has had brush break it twice, yours is protected as it should be. I have seen others have them in the back, mine is low and on the right side of the engine.
   / Is there a need for a coolant overflow tank? #26
Any small durable container that fits in a space somewhere should do. One of those large coffee containers, juice container, water bottle etc.
Might want to make one from plumbing pipe and connectors. Might be the easiest and best.
The best idea yet!!! I can do that with what's available at the Big Box hardware stores. PERFECT!
-R
   / Is there a need for a coolant overflow tank? #28
Could even use some clear tubing on the side for level indication.
Yep, already on it. Just about to leave for a Christmas Eve trip to the toy, ah, tool store. I need something to do while watching the Patriots win over the Jets. :confused3:
-R
2007 KUBOTA M5040F TRACTOR WITH LOADER (A51243)
2007 KUBOTA M5040F...
DOG HOUSE/CONTAINMENT SLID (A50854)
DOG...
2017 Buick Encore (A50324)
2017 Buick Encore...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2007 BIG TEX END DUMP TRAILER (A50854)
2007 BIG TEX END...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
